Key Fob Battery Replacement Question.
Discussion in 'Gen 3 Prius Main Forum' started by uclaozzie, Oct 18, 2021.
  1. uclaozzie
    uclaozzie New Member
    I got message that states I have a low battery on my key fob.
    I've read that replacing the key fob battery may cause the car not to turn on after the fact.
    So, before I replace the battery ... Is it just replacing the battery? Is it that simple? What else do I need to consider?
    I've already purchased the battery.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    I have changed the fob battery many times with no issues. Take the mechanical key out, carefully pry open the halves and replace the battery.
    Montgomery likes this.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Same here as what rjparker said. I've done it a few times, exactly has rjparker describes. Its very easy. The car doesn't miss a beat.
  4. OptimusPriustus
    OptimusPriustus Active Member
    333
    141
    Finland
    Replaced key fob batteries first thing i bought the car. No issues whatsoever. Car was not nearby. It’s keyless so i thought better play safe
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Not unless you damage something in the process.
    Just be careful.
