Key Fob does not work occasionally
Discussion in 'Gen 2 Prius Main Forum' started by fomenter, Jan 19, 2017.
Tags:
  1. fomenter
    fomenter Junior Member
    michigan
    Hello All,
    I have a 07 Toyota Prius BASE and I'm having issues with both of remote controller. They sometimes do not function at all. When I press button, I don't see the red light (car starts fine, the issue is only for locking and unlocking function). Next morning it works fine so I believe it is an occasional thing. Did anybody have similar experience?
    Thanks
  2. Noobprius
    Noobprius Junior Member
    43
    16
    US
    Hello, I'm new to this, but my best guess would be the battery is getting low
  3. fomenter
    michigan
    12V battery or the battery in key fob?
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    That can also be a sign of one or more door lock actuators going bad.
    But I agree that the 12 V battery should be checked.
    And replaced if it is the original one still in there.
    Same thing goes for the batteries in the FOBs.
    If they are more than 3 years old, them might both be going bad too.
  5. fomenter
    michigan
    Whenever I press lock/unlock button in the car, it locks and unlocks all doors fine all the time
    My question is If 12 V battery is low how come the car starts with no hesitation.
    I just measured the battery and it was 12.1 with the light off and 11.7 with the lights on. Are they good numbers?
    #5 fomenter, Jan 19, 2017
  6. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,833
    Hyampom
    12.1 is bad, especially if the car has been run in the past couple of hours. Best check is after it has been off for several hours. Then, I would not be surprised to see it far below 12v
    Toyota Prius: How to Check the 12v Auxiliary Battery Health - PriusDIY.com
    The car can act up once, then be fine for a day, two days or a week or two and then act up again when the 12v is going bad.
    Not something you can rely on to consistently refuse to boot-up when the 12v is having issues.
    #6 cyberpriusII, Jan 19, 2017
  7. Sam Spade
    2,036
    1,023
    2017 Prius c
    NO.
    That does not prove that is the cause of your FOB problem but the battery needs attention.......including checking the voltage while the car is in READY mode (running).
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Michigan? I'll throw cold in the mix. My remote didn't work well in the cold. Maybe it was low on battery but I had to use the mechanical key to open the door occasionally in Reno. Inside the car, everything worked fine. Back in sunny San Francisco everything worked fine.
  9. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Start with the least expensive thing first. Fob battery 99 cents.
  10. bisco
    52,362
    then replace the 12v anyway, it's toast.
