key fob failure
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Aug 2, 2012.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I have a 2010. For the first 25,000 miles, I have been using one of the keyfobs. Today I got into the car, put my foot on the brake as I normally do, and then pressed start button. Nothing happened and I got a message that I had to hold the key up the start button. So I pushed the button on the key fob to release the key. Nothing happened. I tried various positions on the button, but couldn't get anything to happen. Finally, I had to get someone to take me home so that I could get the other keyfob.
    I admit that I do not have good manual dexterity. I would be grateful if any of you could explain to me how to release the key from the fob. I'd also like to know what my other hand should be doing --pulling at the key handle?
    In addition, I assume that I should take the non-working fob to my friendly Toyota dealer so that a new battery can be installed?
    I apologize if this question has been asked and answered before, but this really threw me into a tizzy.
    Thanks for your help.
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    Sounds like the battery in your FOB needs to be replaced.
  3. fuzzy1
    10,167
    Hold the entire key fob up to start button. The RFID unit should be in the fob body, not in that little mechanical key.
    To release the mechanical key, don't press the release button squarely, it won't work. Press in only the end away from the keychain loop. The other end of the button will rock or tilt out of the fob, releasing the key. Pull on the keychain loop, it may be stiff.
    southjerseycraig likes this.
  4. mad-dog-one
    1,181
    420
    Whereabouts Unknown
    To release the key from the FOB, push the button on the side of the narrow side of the FOB having a small key icon and labeled push.
  5. bisco
    49,467
    try your other fob before replacing the battery, it probably still works.
  6. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Fuzzy1, I held the entire fob up to the start button, but couldn't get anything to happen. That's why I then tried to get the mechanical key out,figuring maybe I had to hold the key alone up to the start button. Your instructions for getting the key out do work--thank you.
  7. southjerseycraig
    438
    107
    Cherry Hill, NJ
    yes, fortunately the other fob still works. Still, I will have the battery in this fob replaced so that I always have a working backup. Thanks for your thoughts.
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    Even if your battery in the fob is dead it still should start the car. Holding the fob against the silver ring around the push button, then push the start button at the same time, car should start, if not see the dealer.
  9. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Thank you for that suggestion. It's possible that I did not push the start button, but instead thought that it was enough to hold the fob up. A question: in that case, when it is necessary to take out the mechanical key? What does the key do? thanks again!
  10. bisco
    49,467
    the key unlocks the door if your locked out due to dead fob or 12v battery. a bit of wd40 on the key will help it slide in and out of the for easier if it is tight.
  11. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Thanks!
  12. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Thanks,that's really helpful. Does the door open just by sliding the key in, or is it necessary to turn it?
  13. Germwise
    Germwise Junior Member
    47
    Are you seriously asking this question?
  14. bisco
    49,467
    you must turn it like an old fashioned key.
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Assuming you bought new, I'm disappointed that it sounds like your salesman didn't show any of this to you when you picked up your car.
    My salesman showed me the mechanical key and the slot (on 2nd gens, not the OP's) if the fob battery dies.
  16. 50324prius
    50324prius Junior Member
    39
    iowa
    Plus, depending upon how you have the FOB set up to lock and unlock the car remotely, two motions with the key to unlock will unlock all doors, providing you can get the key out of the fob.
  17. Alpine Hiker
    Alpine Hiker New Member
    One of my key fobs is eating up batteries every couple of days... the key fob is getting replaced under warranty, otherwise those keys, with programming cost over $300.
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    My son had a similar problem, but they lasted about a week. We found he was carrying his FOB and cell phone in the same pocket all the time. Stopped doing that and we haven't had to replace a battery in several months.
  19. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    Fob to the start button explained
    Tbkilb01 likes this.
