Key fob functionality issues
Discussion in 'Prius v Technical Discussion' started by RHG, Feb 4, 2023.
  1. RHG
    RHG Junior Member
    Southern California
    2019 Prius
    Car not responding to key on 2013 Prius v. When I press on fob, it doesn't open/lock doors unless I continue to press button multiple times. (Sometimes it works with one press, other times it needs 10+ presses.) Once inside, the car often doesn't recognize key is there and puts up the warning light. It will only start when I hold key fob next to start button.) I have changed the battery multiple times, thinking that was it. I did just discover that when I press the key fob button, the red light doesn't always illuminate.
    So maybe it's something in the "wiring" inside the fob?
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Or a series of flat button batteries. Store stock is often very dated.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
    Battery upside down?
    Air_Boss likes this.
  4. RHG
    RHG Junior Member
    Southern California
    2019 Prius
    Brand new batteries...they work fine with other devices. I think we can rule that out as the reason.
  5. RHG
    RHG Junior Member
    Southern California
    2019 Prius
    Nope. It does work intermittently well. And other times it just craps out. Thus, it can't be an upside down batter.
  6. Air_Boss
    3,952
    1,083
    New Yawk
    Rinse the fob pc board and micro switches in denatured alcohol to try to remove salts and corrosion?
  7. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Get a new fob................
  8. slow_wagon
    slow_wagon Junior Member
    27
    Upstate NY, USA
    Do you have the same issues with both fobs or just one?
