Key fob pocket start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RedskinPrius, Jan 31, 2013.
  1. RedskinPrius
    RedskinPrius Junior Member
    31
    I have a 2007 base Prius with the square key fob that fits in the (purchased used from dealer).
    I have always placed the key in the ignition to start the vehicle. I had some warranty work done and at check in the tech advised that all prius models with this fob should be able to start with key in the vehicle. Not in the ignition needed.
    Any thoughts on that? It has never worked like that and the tech said all it needs is a battery.
    SCH-I605 ? 2
  2. pjc
    pjc Member
    139
    46
    Bloomington, MN
    You have to have the SKS option. Does your door handle have a little button on it? If yes, you have the SKS option. Does your fob have a silver logo (as opposed to a black one)? The SKS-enabled fobs have a silver logo.
    RedskinPrius likes this.
  3. RedskinPrius
    31
    No on both counts.I figured the tech was just an idiot and proved correct.
    Thanks!
    SCH-I605 ? 2
  4. RedskinPrius
    31
    I assume this is also why when locking the car, no horn beep just a light flash.
    SCH-I605 ? 2
  5. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    If you purchase another Prius, try to get one with the SKS (Smart Key System). With it, all you have to do is walk up to the car, touch the inside of the handle, the door will unlock, enter the car, foot on brake, push power and drive away. All of the time your keyfob stays in your pocket or purse. When leaving the car, push power to power down, exit the car and close the door, push the black button (1 of 3 of them) and walk away.
    A typical Gen II Prius with SKS will have a keyfob with a silver logo.
    And a typical Gen II Prius with SKS will have the little black buttons that look like this.
    Nevertheless enjoy the Prius you have and the great gas mileage that comes along with it.
    Ron
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep, no black buttons a Gen 2 Prius == no SKS. Key must be in the slot to start when there's no SKS.
