Key Not Detected
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JGC61, Mar 27, 2013.
  1. JGC61
    JGC61 Active Member
    214
    101
    Long Island
    While driving the key not detected message appeared three different times during a 50 mile trip.
    The message lasted approx. 30 seconds.
    Any answers.
    Thanks
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    The most popular answer is the rear hatch isn't closed properly and the (light)toggle switch is engaging over bumps or around turns, another possibility is the fob's battery is weak.
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Put your FOB into the slot in the dash. If the problem goes away, replace the FOB battery.
    JeffD
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The 2010 does not have the slot in the dash, assuming the OP's profile is correct. You have to hold the fob up to the power button.
  5. Tande
    Tande Active Member
    502
    302
    Mich.
    By any chance, you don't happen to have an "FOB" from another "Toyota" vehicle, in your pocket, do ya?.......been/there done/that.......FWIW
    3TE likes this.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    +1 Yes that happens!
  7. 3TE
    3TE Junior Member
    40
    Miami, FL
    +1 for the FOB battery. Even though it still works intermittently there is a chance the voltage drop due to sitting in sunlight may trigger the warning.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yup, it's most likely the FOB battery. It's now old enough. The other answers are also possible, but the FOB battery is now old enough to be nearly dead, and the continued "checking" of it while in the car is probably drawing it below the threshold of the "key not detected" message.
