Key Not Detected
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by B_in_WeHo, Mar 8, 2014.
  1. B_in_WeHo
    B_in_WeHo Junior Member
    23
    Over the past month or so, my 2012 Prius Three is being strange. I always keep my key fob inside my purse. Sometimes I have to pull the door handle a few times before it will unlock. Other times it will say key not detected when I try to start the car. I will have to try a few times before it will start. Or the strangest thing is, sometimes when I pull over before my husband and I get home, so he can walk the dogs (who are always with us) and when he gets out of the car (I have NOT turned it off) it will display the message, key not detected. The thing is, he does not carry a fob with him, the only key is in my purse, which is inside the car with me. I thought maybe it maybe it was the key fob so I swapped out the fob I was using with the 2nd one we have and it is still happening.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    Might be something magnetic in your purse effecting the key, might be a weak battery in your key fob might be a 12v battery on it's way out.
  3. retired4999
    2,652
    625
    Eau Claire, Wi.
    If the key fob is in your purse with your cell phone or any other electroinc devices they can block the signal.
    If not that, if your fob is 2-3 years old change the battery in the fob.
    There may be other things but maybe start there first.
    Got me! good job!
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You will get that message if a door is not completely closed.
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    Correct! that to, Check your rear hatch make sure it or other doors are shut tight.
  6. B_in_WeHo
    23
    The rear hatch is closed for sure. It only just started telling me key not detected when I let my husband out of the car before I park. I have had my car for 2 years and it only just started doing it a few months ago.
  7. Okinawa
    Okinawa Senior Member
    1,333
    317
    I have a hunch it is because the FOB is inside your purse. Try taking it out of your purse and put it in your pocket.
  8. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    This sounds like a weak fob battery or interference. A dead fob battery will cause a specific message to be displayed and the start button will need to be pushed with the fob.
  9. BZzap!
    BZzap! Senior Member
    1,607
    877
    I can 't put my cell phone in the same pocket as the key fob. The cell phone blocks the transmitter signal. Also, if the fob battery is weak, the transmitter just doesn't transmit.
  10. Ka8apf
    Ka8apf New Member
    West Central Ohio
    My Prius just started yesterday, sounding the alert when I try to lock the door (keyless entry, supposed to lock and unlock with touch)
    but now it will sound the alert saying that the key is in the car when it is not. I have to use the FOB to unlock or lock the doors.
    Up to this point, no problems--my key, I leave in my right front pocket, and my cell is kept in my left rear pocket
    I've tried to look the issue up on the net and in the owners manual... either I'm as dumb as a box of rocks... or I'm overlooking the fix
    Appreciate any help
  11. bisco
    49,389
    how are the fob battery and 12v health? have you tried the second fob?
  12. Ka8apf
    Ka8apf New Member
    West Central Ohio
    just changed the fob battery about a week ago, the 12v, I'm not sure
  13. Ka8apf
    Ka8apf New Member
    West Central Ohio
    and, no, I haven't tried the second fob... didn't think of it, because the fob works, the senson on the hadle is what is giving me the issue, won't let me lock with my hand
  14. Ka8apf
    Ka8apf New Member
    West Central Ohio
    Huh! Turns out it was related to Occam's Razor! I live in West Central Ohio, and it had gotten relatively warm, got cold again, so I threw my heavy coat in the passenger seat for the couple days I had the 'key in car' issue... you would never guess what was in the pocket of my heavy coat!!!
    Thanks bisco for your help!
    Raytheeagle likes this.
