Key problem - lost inside car and I can't find it.
Discussion in 'Gen 2 Prius Main Forum' started by Ruth Hoppe, Nov 20, 2019.
  1. Ruth Hoppe
    Ruth Hoppe New Member
    Sonoma, CA
    I have 2 keys but apparently I've lost one key inside the car and I can't find it. I can't lock the car with the other key because the car thinks there is a key inside the car, which is true.
  2. ydpplqbd
    ydpplqbd Active Member
    542
    250
    If it was me, I would get a box, or plastic storage box, and garbage bag. Then, I would start cleaning out every nook and cranny in the car. Just my two cents ("$0.02").
    Eventually, you will find the other key fob (and also have a fabulously clean and organized car).
  3. BPC Auto
    BPC Auto New Member
    Three Touring
    Turn car on... And take things out, and then close door. If it is not beeping 3 times then the key is still inside.
    My suggestion would be the space between the arm rest center console for seat belt. I always drop my keys in there.
    Personaly i hide the fob in the sunglass holder. nobody can figure it out.
    49,371
    get down low with a flashlight and look at the inner front seat rail areas from front and back, sliding the seat in the opposite direction
    Skibob, jerrymildred and fuzzy1 like this.
  5. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    If need to lock it you can do so with the manual key in the fob.
  6. ETC(SS)
    6,541
    Park in a garage?
    It might not be in the car if you're trying to lock the car at home and the other key is on a hook by the car.
  7. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    If you turn the SKS button off you will be able to lock the car with the other fob. You will need to use the lock and unlock buttons for the doors and insert the fob into the slot to run the car though.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    I have these in all my cars they sell cheaper plastic ones. Catches anything dropped and also catches alot of dust and debris. They work great. There a AS Seen On TV.
    key fob is probably in between or under the seats.get a flashlight.
    Raytheeagle and ydpplqbd like this.
  9. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    If the missing fob is not in the car the other fob would lock the car. The car is smart enough to work out if the fob is inside the car or not. The OP is correct, the fact she can't lock the car means the missing fob is inside the car. Somewhere.
  10. ski.dive
    ski.dive Active Member
    893
    230
    Hutchinson Island,FL. Mt. Snow,VT
    She's NEW to the PRIUS world
    = She probably left the Prius running and could NOT lock the door.
    edthefox5 likes this.
  11. bisco
    49,371
    you figured that out from her one post?
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    This a serious suggestion.
    But if you've looked, and you can't find it?
    Sometimes just having someone else look is a good move. You can be overlooking some area or spot that a new set of eyes might see.
    So my advice is give up, and have friend take a look for you.
    If that doesn't result in a found fob?
    Then 2 people looking is better than one.
    And yes, you need a good flashlight.
    Kaptainkid1 likes this.
  13. RacerX
    RacerX Junior Member
    Des Moines
    You can still lock the doors if you press the button to lock the doors by the window controls on the drivers door while exiting. And unlock them with the one fob.
