Key to remove tire lug nut?
Discussion in 'Gen 3 Prius Main Forum' started by Saul Sanchez, Oct 30, 2020.
  1. Saul Sanchez
    Saul Sanchez New Member
    Garland
    Soo I bought this car less than a year ago, and I took it to the tire shop to get a patch due to a nail, the guy said if I had the key and I did not and they said they can't take the tire off without it and after looking I see what they meant, where do I get a replacement?
  2. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    There's no key for OEM lug nuts. Yours must be aftermarket. I'm surprised the tire shop didn't have one -- unless yours are unusual. Can you post a pic?
  3. Leadfoot J. McCoalroller
    8,158
    7,663
    Pennsylvania
    2018 Prius c
    It's pretty unusual for a tire shop to fail to remove a wheel lock- this is totally normal business for them. Typically they are equipped with some generic keys plus a few special tools which will (destructively) remove the offending lock such that an ordinary lugnut can be used as a replacement.
    Honestly I'd just try a different tire shop next, something is up with this one.
  4. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I have aftermarket security lug nuts for my winter steel wheels -- they came with the set when I bought them. When I misplaced the key, I just went on Amazon and and found a replacement just by sight. It fit perfectly... then of course I found the original. So now I have two.
    If I worked in a tire shop, I'd own several of the most common ones just for convenience.
    jerrymildred likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    OR visit an auto parts store if one is nearby.
    Best to remove them completely; each wheel likely has one.
  6. Mendel Leisk
    41,983
    I replaced our security lug nuts with regular, just figure they're more trouble than they're worth. Got gorilla brand, on Amazon. You can enter your car stats on Amazon to verify compatibility. Or go straight to gorilla site I guess.
    Attila Fekete and jerrymildred like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Normally, tire shops have a selection of keys and can remove them. I swapped out the keyed nuts on my last Prius but haven't done so yet on the Prime. I'm getting my next free tire rotation next weekend and will get that done then.
  8. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Easy, since your on the internet already go on to ebay and find the one that matches the pattern on the lug nuts.
  9. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Did you get any manuals with your car? Among mine was a card with the key number.
    I don't know how many different patterns there are.
  10. Siward
    Siward Active Member
    314
    128
    Toronto
    I'm in Canada, but I have a set of OEM Toyota locking lug nuts. And yes, it has a key. It depends if you bought the nice Toyota alloy rims and choose to buy it with lockable lug nuts. The previous owner could have also replaced them with aftermarket locking nuts too.
    I would search your entire car trunk/compartments for the key. I usually keep my key with the car in case I get a flat tire. It makes no sense to put it anywhere else. It should look something like the middle socket in the below link. (The link is not for the Prius but it does look like mine).
    A good tire shop should have ways to remove the lock. They could use similar keys. I also heard some of them can drill the whole lug nut off (in which case you need to buy new ones).
    You can try shopping for a similar key but it is hard to say. Good luck.
    #10 Siward, Nov 2, 2020
  11. Mendel Leisk
    41,983
    Google Eric the car guy locking lug nut removal for some tips. Funny in places too. :)
