Key was in ignition - believe was left running - despite charge no power of any kind
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by AlaskaC, Dec 25, 2019.
  1. AlaskaC
    AlaskaC New Member
    Alaska
    2015 Prius c
    Hello All.
    Merry X'mas PriusChat Forum Members;
    My wife passed last week. She has a 2015 Prius C which she loved - and I'm rather fond of as well. I believe she was in a dazed state before her ultimate demise and in that state had left the key in the ignition and most likely the car running. This was all unknown to me in my attempts to save her. Yesterday, I discovered no power to the car @ all - I tried to hook up a trickle charger in the method Toyota advises and the trickle charger indicated 100% charge - but, still no power at all (no indicator lights on display, etc) - but, the 12V receptacle does energize (?). As you can tell by my avatar - I'm a bit more familiar with non-hybrids (namely Focus ST's (don't hold it against me)) - so, here I am beckoning to those of you out there in the priuschat community...what do you think is wrong? How would you recommend me go about troubleshooting? I'm trying to tread lightly due to my unfamiliarity with hybrid systems...
    I apologize for the grim details. Thanks in advance!
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,520
    Pacific Northwest, USA
    My deepest condolences to you... Hooking up a different 12v battery via the jump start instructions in manual would be a good first step. Trickle chargers take a very long time to fully charge a 12v so the 100% reading might be in error.
    Are there any other symptoms or details of what you can tell happened with the car when this very difficult moment happened? Do you think it ran out of gas?
    Once you get some power in the car, there might be warning lights and you'll be able to read the stored error codes that triggered the lights, which will point to specific details of the problem.
  3. AlaskaC
    AlaskaC New Member
    Alaska
    2015 Prius c
    Hi PriusCamper; Thank you for your kind words. I didn't rule out the car running out of gas - but, would this necessarily affect the electrical system? Esp this diminished state? When I was going back and forth in the car - I did notice on ONE single solitary occasion the door ajar indicator came on and thought I was making progress - but, alas that never happened again and its totally dead. Guess, I'll need to check connections and then pull the battery out from under the back seat and check it out. Just hoping I can self remedy this issue - as my username indicates, I'm stuck in Alaska - so resources are far and few between and if available...pricey. Thanks. BTW...Merry X'mas...
  4. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    My condolences
    Not sure if there is a auto shut off other than running out of gas.
    Not sure what would happen in that case, but quite possible that it ran down the hybrid battery all the way.
    You may get lucky and be able to disconnect the 12v battery for a few minutes and then reconnect.
    But perhaps if that is low, you may need to trickle charge it or jump from the jump
    points under the hood. Under the fuse box on the drivers side, flip the RED thingy over,
    connect the + RED and then - Black to perhaps a metal piece of the engine for ground.
    But being this is a Prius, be very careful to not cross them, or cross the other side of the jumper cables etc.
    In the event that the Hybrid battery fully ran down to danger territory,
    you may only have the option of bringing to a Toyota dealer to charge up to safe levels that battery.
    But try out the 12v and see if codes appear or if everything is all good from there.
  5. Leadfoot J. McCoalroller
    7,176
    6,724
    Pennsylvania
    2018 Prius c
    You have my deepest sympathies.
    A 4+ year old 12V battery taken to deep discharge in combination with typical Alaskan temperatures for mid-December can permanently ruin the 12V battery. It may not be able to accumulate a meaningful charge from any charger at this point.
    The setup you've described could have turned into a cascading failure as follows:
    Car left running, engine recharges the big high voltage (HV) battery as needed, cycling on and off. The DC/DC converter in the hybrid power system produces low voltage power to top-up the 12V battery much the way a traditional alternator does in your Ford.
    Eventually the fuel runs out and the engine stalls. The hybrid computer doesn't have the greatest awareness that the problem is fuel exhaustion, so it will try to start the engine again. Starting power comes from the HV hybrid battery, not the 12V. However, the 12V battery is carrying the load of several ECUs plus any 12V accessories that may have been left on.
    After X attempts to start the engine, the HV battery will have run itself down. The 12V battery is still operating the ECUs and hotel loads.
    With the HV battery exhausted, the DC/DC converter can no longer replenish the 12V battery. The ECU load draws that battery down.
    So, to get back up from this situation the first thing is to get 12V power back up. Connecting another 12V battery via jumper cables is a good start. That lets you get the electronics booted and see if it's got trouble codes logged. If it really was run down, recently-set codes are likely lost. However it will start generating new ones if it attempts to start the gas engine and can't due to an exhausted HV battery.
    The bad news is that a discharged HV battery needs to be mains-charged before it has enough power to crank the engine. It's a really unusual charger. Only Toyota dealers have them. Not all dealers have it; sometimes one must be brought in from another dealer or regional hub.
    I'm not there anymore, but I grew up there. I know it can be a tough season. Stick close to anyone you can.
    scona and dig4dirt like this.
  6. PriusCamper
    11,105
    4,520
    Everything Leadfoot said above is correct... But if you do DIY work on cars you got this... YouTube videos will show you how to pull out the hybrid battery and then you can remove the connectors and charge up the individual 8 volt modules... There are 20 of those modules and you will need a hobby charger that's designed to charge up remote control toy cars, planes and boat NiMH batteries. These chargers can be bought online for $30 - $50, I can send you links to the best ones if you want.
    The other more expensive option, but easier because you don't have to take the battery pack out of the car or take the car apart very much is buying a charger and wiring harness in the $400 range here: ProlongĀ® Battery Charger - Hybrid Automotive
    Hopefully the problem is just a 12v battery failure due to cold weather and the hybrid battery still has enough charge to start the engine.
    #6 PriusCamper, Dec 25, 2019
  7. AlaskaC
    AlaskaC New Member
    Alaska
    2015 Prius c
    Dig4dirt, leadfoot, and PriusCamper - thanks for your input and kind words. Duly noted everything you have advised. I took the 12V out and have a low amp trickle charger powering it up...crossing my fingers that will be it - then I'll make my way to finding a new battery for it. I'll keep you posted on how this transpires...Again folks, I appreciate everything and Happy Holidays...
  8. AlaskaC
    AlaskaC New Member
    Alaska
    2015 Prius c
    Folks;
    Got the battery charged up - everything seems to be copacetic. But, I'm not taking any chances and am going to purchase a new battery @ the local Fairbanks Toyota tomorrow (don't need to be stranded in a - 40 degree clime). Car is not throwing any codes...
    Since, I've got your attention - anyone able to offer guidance towards a firewall pass-through? Would like to install electrical accessories (namely auxiliary lights for the perpetual darkness esp on the country roads).
    Thanks again all. Happy Holidays and stay classy.
    (pic of said vehicle this past summer attached)
  9. Leadfoot J. McCoalroller
    7,176
    6,724
    Pennsylvania
    2018 Prius c
    Glad to hear you've got the vehicle recovered properly. I think it's wise to replace that battery after the discharge/freeze combo.
    Thanks for the picture! Your car looks great. I can't place the setting; been a long time since I left. My first job ever was delivering the News-Minus.
    I wish I could suggest a solution for a wiring path. So far the only thing like it I've done on ours was a 4-wire trailer lighting setup, but obviously that's the back of the car.
  10. PriusCamper
    11,105
    4,520
    Congrats on it being less of a hassle than it could of been...
    When I run wires, I look for an existing rubber grommet that wires are going through in the firewall and run it with those wires, or poke a hole in the grommet next to those wires...
  11. AlaskaC
    AlaskaC New Member
    Alaska
    2015 Prius c
    Thanks - this pic is on Eielson AFB (when it's not - 40 (like it is today)). Well, if I figure something out - I'll try to contribute to this forum. Happy Holidays...
    Thanks! I feared the worst. I typically do the same - but, the existing grommets and pass-throughs aren't as conspicuous as...say...on a 2016 Ford Focus ST...Do you have a specific location you recommend? Thank you.
    #11 AlaskaC, Dec 28, 2019
  12. PriusCamper
    11,105
    4,520
    If it was a Gen2 Prius I would, but I've yet to work on a Prius C....
  13. Leadfoot J. McCoalroller
    7,176
    6,724
    Pennsylvania
    2018 Prius c
    Gotcha, I've only been on base twice, airshows etc. Still nice to see a pic from "home."
    I'm not near our c today, but it occurred to me that both the main underhood relay box and cabin fuse panel are at the extreme left side of the firewall. I'd be very surprised if the wiring between them didn't transit the firewall in the same plane.
    You can rent the real-deal Toyota service manual for $20 and save the PDFs for future use. It helped me a lot when I added a carplay stereo and a dashcam to ours.
    scona likes this.
