Keyboard Settings - Ignored on Bluetooth/Phonebook?
Discussion in 'Gen 2 Prius Main Forum' started by Manksgloob, May 23, 2006.
  1. Manksgloob
    Manksgloob Member
    243
    Hello,
    I have a 2006 Prius (manufactured in 04/06).
    I set the default keyboard layout to QWERTY (via Menu) and for the most part it has complied.
    However, under the phonebook the keyboard there still uses the ABC layout with no option to change it.
    Is this behavior normal?
    I dislike how all the keyboards follow one layout but then this one in the phonebook decides not to.
    I apologize if this has been posted before; searching yielded no similar topics.
  2. Manksgloob
    Manksgloob Member
    243
    Does anyone have any insight on this issue? Please?
    Perhaps I was too specific in my topic title. Barely anyone bothered to click and read the thread :p
  3. Manksgloob
    Manksgloob Member
    243
    *bump*
    No opinions?
    Anyone?
  4. chayashida
    chayashida Junior Member
    My opinion is that it sucks. I'd like to have a Qwerty keyboard for all input.
    I don't think there's going to be a fix for it, though, unless you can upgrade software for the Prius. This isn't something easy, like updating map data.
    Post something if you find it, but I wouldn't hold my breath if I were you. :(
  5. brooks.filmond@gmail.com
    [email protected] New Member
    <div class='quotetop'>QUOTE(Manksgloob @ May 23 2006, 08:09 PM) [snapback]260084[/snapback]</div>
    I took delivery of an '07 Prius this week and it has the same problem unfortunately.
  6. walt
    walt New Member
    195
    Bel Air, MD, USA -=- Blair, Merlin, Merka
    <div class='quotetop'>QUOTE(Manksgloob @ May 23 2006, 11:09 PM) [snapback]260084[/snapback]</div>
    probably assumed that users want to have something that looks like their phone dialpad.
  7. clarkeb
    clarkeb New Member
    27
    Then maybe it should be made so you have the four rows of three with the numbers like on a phone and you just have to hit the number one 3 times for the letter C, etc!
  8. Manksgloob
    Manksgloob Member
    243
    Whoa, replies.
    My guess is that either Toyota engineers don't know this is a problem, or they know and just don't care enough to fix it.
    Maybe if enough people inquire as to what the issue is, then they might do something about it.
    And yes, it is possible to update the software running on the Prius via a firmware update. It's what they did to the 04's that were stalling and shutting down on the side of the freeway due to a software error.
