Keyfob LED flashes in RED?
Discussion in 'Gen 5 Prius Main Forum' started by TheGodX, Feb 1, 2025.
  1. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    Any button press makes the little LES on the fob flash in red; is this normal for it or does that means its running low and needs to be changed?
  2. Dochatley
    Dochatley Junior Member
    17
    Dallas
    2024 Prius
    Change it and see. Cheap insurance.
    52,401
    Is it working? Anything in the manual?
  4. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    works fine. Just the red LED tends to give feeling that its a low battwry sign. The manual just says: "If the battery is low, the LED indicator on the key surface does not turn on." And that a low key battery warning will be displayed. So i was wondering if others also noticed their keyfob LED being flash in red or does it turn green or white etc.
  5. SkiLodge
    SkiLodge New Member
    PNW
    2024 Prius
    Limited AWD-e
    I've had my new Prius for less than 2 weeks. The red LED always flashes when I press a button on the key fob.
    Looking at the Owner's manual:
    and
  6. mva
    mva Member
    157
    92
    B.C. Canada
    2024 Prius Prime
    SE
    I have seen mine flash too - no idea why.
  7. Trollbait
    12,689
    I've had TV remotes flash a LED whenever a button was pushed.
    Seems this is just to let you know pushing the button did something, and it's working.
    Gorgonzola likes this.
  8. bisco
    52,401
    on previous models, led flash means the battery is good
