Keyless entry Modification
Discussion in 'Gen 2 Prius Audio and Electronics' started by adrenalinwill, Jun 16, 2004.
  1. adrenalinwill
    adrenalinwill New Member
    43
    Irvine, CAlifornia
    Has anyone figured out how to reprogram the keyless entry to open the rear doors when activated from the driver's side? When you open the door on the passenger side, all four doors open. From the driver side, only the driver door opens.
    Sure would be nice to be able to open the rear doors also from the driver side....helps when you've got a handfull of children, groceries, or plans.
  2. tag
    tag Senior Member
    2,526
    Chicago
  3. CarlK
    CarlK New Member
    30
    North Carolina
    :idea: Maybe Toyota could save some money by making the user manual an extra cost option since so many people seem to not use it.
    End of sarcastic rant!! :mrgreen:
  4. David
    David Member
    169
    Vero Beach, Florida
    Better yet, charge for the manual but hire a techie that can write well.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    at $10 a day for download privliages, Toyota IS charging for everything else.
  6. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    I would kill to have the sensors on the rear passenger doors. I often try to open those doors first to put stuff in the back seat.
  7. adrenalinwill
    43
    Irvine, CAlifornia
    Ah Ha! Sarcasm! Funny! So funny I almost forgot to laugh. Didn't yo ma ma ever tell you "if you don't have anything nice to say, shut the hell up?"
    On the other hand. Thank you Tag!
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    It's quite simple to grab the driver's handle (touch it lightly from the inside), then open the rear door.
    Or... you can quickly grab the hatch handle - not long enough to open, just long enough to get the doors to unlock.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Even MORE "better yet". They could hire some programmer to make use of that dandy screen in the middle of the dash and provide an application to set all of those options that now require "while holding this, shove your left big toe into your right ear, press that button twice, and hop up and down for 3 seconds" procedures.
    Geez what a SIMPLE thing that would be. I'd do it for free and I don't even have a Prius!! The lack of such a thing is a glaring and stupid weakness in a technologically advanced product. I can see the current method being reasonable if they didn't already have a display in the car, but they DO and it is a touch display at that, don't even need another input device!!!!
  10. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Thanks Rick!
    Thanks Rick!
  11. jamarimutt
    jamarimutt New Member
    985
    I agree!!! It should be possible to do many of these things using the screen: turning the reverse beep off, turning the maintenance light off, programming the locking sequence for the doors, etc.
    Since so many people prefer to watch TV instead of reading, why not deliver the manual also in a cd/rom? At the very least, a PDF file should be available for downloading from Toyota's website.
  12. naterprius
    naterprius Senior Member
    1,843
    Adding sensors to the back door handles
    Has anyone considered adding sensors to the back door handles for SE/SS? It seems this would be relatively easy; the sensor could probably be spliced into the front door sensor harness without a problem. (I'm guessing.)
    Any thoughts?
    Nate
