Keyless Entry not responding 2013 Prius C 1
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Royce Rezendes, Sep 27, 2022.
  1. Royce Rezendes
    Royce Rezendes Junior Member
    Lawrence, KS
    First off my car is a 2013 Prius C 1 that I bought brand new. I have zero other issues with the car and there are no warning lights or codes that come up through the OBD2 port.
    Keyless entry (non smart key) just the Lock/Unlock/Alarm buttons on my keyfob stopped working. I replaced the battery and made sure it had good voltage and still nothing. I purchased a rtl-sdr radio receiver and was able to monitor the 315 Mhz range and saw that every time I press a button, a signal was being transmitted from the fob. The mechanical key and lock/unlock buttons inside the car still function perfectly. My auxiliary 12V battery shows 12.28 V on my multimeter while car is off, although it is the original oem battery from 2013 (again no other issues in the car). I tested with a multimeter all Relays and Fuses, every single one is fine. I removed the door/tpms receiver module to inspect the electronics and everything looks pristine on it, I noticed there was no power whatsoever showing up on the connector that supplies it power inside the car. I assume there should be 12V there even when the car is off because you can always use your key fob to lock/unlock when car is off. This happened out of nowhere, nothing happened, didn't drop the keyfob or have anything happen on the day it stopped working. All I can think is the wiring is disconnected or broken somewhere inside the car from the battery to the connector that supplies the receiver module. One thing to note is that a few weeks prior to the key fob stopping working I actually ran into a parking pole on the driver's side front wheel well, maybe some wire on that fender got pinched? I don't know what to do/test next, I want to avoid paying hundreds of dollars to a dealership if at all possible.
    #1 Royce Rezendes, Sep 27, 2022
  2. Royce Rezendes
    Lawrence, KS
    So, I feel stupid and the issue is basically fixed (pending me buying a good battery). I supplied the keyfob with 3.1V directly from my bench power supply and it works. Even though the fresh out of the pack (Amazon likely) battery reads 3.27V. So I guess the battery couldn't provide enough Amps? I'll be heading to Walgreens...
    52,405
    please let us know the outcome. is the battery connector tight? did you have pos and neg correct?
    a new fob battery should measure 3.3v
  4. Royce Rezendes
    Lawrence, KS
    Yes, bought a new battery (measuring 3.3v) and it works perfectly. So even though when you look up a cr2016 battery it says it's only 3v, I guess it must be 3.3v and anything lower means the battery is dying/dead, even 3.27v. Or the batteries I have are fake/low quality.
  5. bisco
    52,405
    a lot of low quality stuff online unfortunately. it's hit or miss.
    all batteries have a 'nominal voltage rating' but are higher than that when new and fully charged
    Royce Rezendes likes this.
