keyless entry not working
Discussion in 'Gen 2 Prius Technical Discussion' started by Hard2Choose, Nov 7, 2012.
  1. Hard2Choose
    Hard2Choose Junior Member
    I have a 2007 with 247,000 miles. Recently when I go to get in the car in the mornings, the keyless entry will not work. Usually I just touch the doorhandle & it opens. It won't even open when I push the unlock button on the clicker. I have to take the key out of the remote to open the door. This only happens first thing in the morning when it is cooler & there is dew on the car. Later in the day, everything is fine. Any ideas?
  2. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    Replace the button battery in your remote.
  3. logopenn
    logopenn New Member
    16
    I have same problem I replaced the battery in fob now it won't work at all
    49,490
    did you test the new fob battery before installing it?
  5. JC91006
    16,482
    8,400
    Put the old battery back and see if it works. Could be your new battery is not good
    SM-N900P ?
  6. logopenn
    logopenn New Member
    16
    I did not test the new battery for fob and don't have the old one I can go buy a new battery for it again and see if that helps
  7. logopenn
    logopenn New Member
    16
    I went back to advance and got another battery tested it while I was there and it worked went out to the car and it worked unlock button does not work but the lock and when I walked up to the car and just open the door it works
  8. JC91006
    16,482
    8,400
    Sounds to me you have a sticky button. That will normally drain your fob battery if it's stuck. You have to correct that problem or you'll be back to the situation again. Youtube has some videos on a sticky button
    SM-N900P ?
  9. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    These fobs spend a lot of time in grimy pockets. I bought a $7.00 soft case for it (Amazon), similar to the cheapies you see for smart cell phones (couldn't find an expensive nicer one with some water resistant qualities). I put the FOB in a plastic bag before putting it in the case.
  10. usnavystgc
    3,159
    989
    Tucson, AZ
    I got the same soft case. I love it so much, I bought one for my TCH as well.
