Keyless entry reprogramming
Discussion in 'Gen 2 Prius Main Forum' started by PsyPrius, Oct 29, 2009.
  1. PsyPrius
    PsyPrius Member
    100
    Wilmette, IL
    Hi all-
    I have a 2006 Prius with keyless entry that was recently serviced and have full battery disconnect. Prior to disconnect, I had my keyless entry programmed to:
    1. unlock driver's side door when accessed on driver's side
    2. unlock all doors when accessed on passenger side
    3. unlock hatch AND all doors when accessed at hatch.
    Toyota says they could program 1 and 2, and it is impossible to program 3, that when accessing the hatch keylessly, only the hatch unlocks.
    Does anyone know how to reprogram the hatch unlock to unlock all doors as well?
    Thanks!
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    From the owners manual:
    CHANGING THE DOORS TO BE UN-LOCKED
    Each time you push the lock button together with the panic button on the smart key for about 5 seconds with the hybrid system off, the setting for door unlocking will change as follows:
    1.Driver’s door unlocking mode: If you perform smart unlocking operation on the driver’s door, it will unlock. Performing unlocking operation on the front passenger’s door or back door will unlock all the doors. When the system switches to this mode, one beep sounds inside the vehicle and two beeps sound three times.
    2.All doors unlocking mode: Performing smart unlocking operation on either front door or back door will unlock all the doors. When the system switches to this mode, one beep sounds inside the vehicle and two beeps sound twice.
    3.Single door unlocking mode: The driver’s door or back door on which you perform smart unlocking operation will unlock. However, performing unlocking operation on the front passenger’s door will unlock all the doors.
    When the system switches to this mode, one beep sounds inside the vehicle and two beeps sound once.
    I believe you want mode 1.
    2 people like this.
  3. PsyPrius
    PsyPrius Member
    100
    Wilmette, IL
    Does the trick! Thanks much!
