Keyless entry / Safety
Discussion in 'Prime Main Forum (2017-2022)' started by TayUniversal, Aug 30, 2018.
  1. TayUniversal
    TayUniversal New Member
    Johnston, Iowa
    So, because all that is needed to unlock the car is for the key fob to be within a short distance, does this mean that even if I am in my car that someone could just come up to my door and open it even though im inside?
    Just wondering because I'll be driving halfway across the country in a few weeks and might pull over to catch some shuteye every now and then. Wanting to make sure someone wont be able to just open my door while im inside snoozing.
  2. Tideland Prius
    16,127
    The key needs to be on the outside of the door to unlock it from the outside. If you want to be extra careful, put the key in your right pocket (the side that's towards the centre of the car). i'm thinking that if it's in the left pocket and you lean against the door while sleeping or roll close to it, it might mistake it for being outside. It's a slim chance but putting the key in the middle of the car reduces the chances since it'll be detected by the interior receivers.
  3. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    You can have the “smart” feature turned off by the dealer. The fobs will then work ONLY via the buttons only like a “normal” keyless entry system.
    #3 schja01, Aug 31, 2018
  4. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    You can temporary disable the key from being a smart key by pressing unlock twice while holding the lock button. The red light will flash four times if successful. It will stay disabled until you press any button on the key.
    Putting it in a metal container like an empty tin of mints could also work.
  5. Paul Miller
    Paul Miller New Member
    Eugene, Or
    Do all 2014 Prius' have keyless entry? There is no button under the steering column.
  6. bisco
    49,385
    yes
  7. Tideland Prius
    16,127
    To further @bisco’s reply, yes they all have keyless entry but the button below the steering column is tied to the Smart Key System which was optional.
  8. bisco
    49,385
    was it optional in 2014?
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,153
    2,204
    Taylors, SC
    Even simpler. Get an RFID key fob blocking pouch or just cover the fob with aluminum foil. Lock the doors wit the switch on the door arm rest.
  10. bisco
    49,385
    of course, this is a prime forum
  11. Tideland Prius
    16,127
    Lol. I saw 2004. And that was reinforced with the “button under the steering column” which was the SKS OFF button.
