keyless entry/smart key/remote fob failure trouble shooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gcarl, Oct 15, 2016.
  1. gcarl
    gcarl Junior Member
    Upon picking up my 2004 from my trusted mechanic who changed the a/c evaporator coil, I discovered that somehow I have lost all functions of the remote fob, including keyless entry/starting, door lock and panic button functions. Could there be some simple connection, programming issue which could restore these functions which would not include another disassembly of the dashboard, which appeared to be an unbelievable job when I saw it all apart. Any thoughts (I HAVE replaced the fob battery).
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    First thing, check that the SKS button on the lower dash is ON.
    Is this your only FOB?
  3. gcarl
    gcarl Junior Member
    Doug: Thanks for the reminder of the "key" button under the steering column. In 12+ years I have never used that button. Now the keyless entry/keyless start works with both of my original fobs, but none of the buttons on the fob work to lock/unlock or sound horn/blink lights with the panic button on either fob. I just now replaced the fob battery with one from another new package Any thoughts on that issue?
  4. fotomoto
    5,602
    3,778
    So. Texas
  5. bisco
    49,435
    and check your 12v, he might have drained it while working.
  6. gcarl
    gcarl Junior Member
  7. fotomoto
    5,602
    3,778
    So. Texas
    Sorry no. BTT Good luck!
