Keyless entry suddenly stopped working
Discussion in 'Newbie Forum' started by NikiB, Aug 31, 2017.
  1. NikiB
    NikiB New Member
    Ashmore, Gold Coast Queensland Australia
    Hi all, I have a specific question about the sudden failure of the keyless entry function.
    Yesterday, when I tried to start the car with the starter button (unlock function worked perfectly at this point), the Prius dashboard displayed the key symbol, indicating that it did not recognise that the key was in the car, so I wondered if the battery was losing power even though it was only a few months old (replaced earlier this year) .
    I had another Fob which needed a battery replacement, so I thought I'd have Fob 1 battery checked and also have a new battery put into Fob 2. Everything was working fine prior to having the battery checked at the battery replacement store.
    The problem is now that neither of my smart keys will operate the smart entry. Both keys will start the car from inside when I press the starter button, but neither key now operates the lock/unlock function.
    I also tried using the lock/unlock function whilst sitting in the car and I noticed that I needed to press the Fob button a couple of times before it worked (on both Fobs), so I wonder if the chap who checked and replaced the batteries has perhaps caused the buttons to stick?
    I switched the smart key function cancel button off and on a couple of times, but this hasn't made any difference.
    I did wonder whether this situation might also be an indication that the 12Volt battery in the boot might be starting to fail and it seems that this is a possibility after reading previous posts. However, I don't want to go to the expense of purchasing another 12 volt battery if this is not the problem, hence my query here first.
    As it stands right now, I can't lock/unlock my car with the remote, and will have to use the manual key - very inconvenient.
    I hope there is a simple, affordable fix for this. I really do not want to have to take the car to have the keys re-programmed. I've found an article about how to program the keys myself, but I'm hesitant about taking this step as I could really mess things up.
    Thanks in advance.
  2. JC91006
    16,748
    8,553
    Maybe the batteries you bought were bad?
    NikiB likes this.
  3. NikiB
    NikiB New Member
    Hi and thanks for responding so quickly.
    I only purchased one battery, but I did have the chap check the other battery to see if it still had a good charge. He didn't replace that battery. The car is able to start with both Fobs, so it if was faulty batteries, wouldn't that affect the starter motor too, as well as the unlocking/locking function? Both Fobs work except for the locking/unlocking function. It just seems very odd that Fob 1 suddenly stopped working after the battery cover had been taken off and checked.
    I've just checked the receipt for the 12V battery and it was replaced in May 2014. I suppose it could be nearing the end of its life?
    RCO likes this.
  4. JC91006
    16,748
    8,553
    So now I'm guessing he changed the good battery out of fob 1, and replaced with an inferior new battery. Didn't do anything to fob 2 because he mixed up the working and non working fobs.
    So you have 2 non working fobs. Just a theory.
    You should bring 1 fob and change the battery again, see if that changes things. Don't do both at the same time again
    Just for fun, try resetting the car by disconnecting the 12v battery for a minute and reconnect it
    #4 JC91006, Aug 31, 2017
    NikiB likes this.
  5. NikiB
    NikiB New Member
    Thanks for the suggestion about disconnecting the 12V battery. Please excuse my ignorance, but how do I do that? Just unplug the leads?
  6. JC91006
    16,748
    8,553
    You can remove the negative lead, use a 10mm wrench to loosen it. No need to touch the positive side.
    Most auto part shops will test the battery for you, maybe you can have them disconnect it for a minute while they test it? Get 2 things out of the way
    #6 JC91006, Sep 1, 2017
    NikiB and RCO like this.
  7. NikiB
    NikiB New Member
    Thanks again. I did a Google search to see how to replace the 12V battery - think I'll leave that one to the experts. In the process I came across a couple of videos that showed how to check the Auxiliary battery on the diagnostic screen.
    In 'Maintenance' I checked the Battery, and as suggested on the YT videos, I switched the lights on 3 times to get the diagnosis. My screen looked different to the YT videos (I'm in Australia and they are US videos) but after flashing the lights, the message came up to change the battery, so I suppose that's the problem. It is 4 years old.
    Also, when I started the car today the key symbol came up again, which I think means the car isn't recognising that the key is there. So, if the 12V battery needs replacing, would this cause the issue with the key (i.e. car not registering that the key is in the car and the lock/unlock function)?
    Thanks for your help thus far.
  8. JC91006
    16,748
    8,553
    You should have the car's battery tested, make sure it's bad before you replace it. The key issue may not be related to that at all.
    I find it odd that it happened after the battery change. So I would concentrate on possibly replacing 1 fob battery (maybe from another vendor) and see if things change
  9. NikiB
    NikiB New Member
    Okay thanks for that advice. I will have the 12V battery tested just to make sure.
    And I'll take one key Fob to another battery place and get a new battery as suggested by you. Thnx for taking the time. Cheers
    PS: It might be a couple of days before I resolve this (weekend coming up) but I'll let you know how it gets sorted.
    Again, thanks. Cheers
    RCO likes this.
  10. NikiB
    NikiB New Member
    Hi JC91106 - just thought I'd let you know current situation. The situation seems to have rectified itself and I have no idea how.
    Yesterday I'd decided to get battery for Fob 1 changed again, as you suggested.
    When I left home, I had to insert the key as the car was still not recognising the smart key, but as I was getting out of the car, I automatically pressed the lock button (out of habit) and it worked. After that, it has worked every time (so far).
    In my search for a solution, I read about how the Fob signal still communicates with the car if they are within 15 feet of each other, which mine is. So I've decided to turn off the smart key function at the end of each day and see if that lengthens the life of the Fob batteries. I haven't driven the car today so I'm hoping that all is well.
    I'll let you know if there's any further issues, but thought you may be interested to know that it seems to have righted itself (hopefully). I'm keeping Fob 2 upstairs and a long way from Fob 1.
    Thanks for taking the time to offer solutions. I am hoping that this is the end of it (until the battery really needs changing).
    Cheers
    RCO likes this.
