Keyless entry works, but keyless ignition doesn't.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chow, Jan 4, 2020.
  1. Chow
    Chow Junior Member
    United States
    I've just bought a used 2007 Prius that only came with one key. The key is the one with silver logo at the back. Keyless entry to lock/unlock the car works fine, but the car only starts with the key in the fob slot. when I tried starting the car without the key in the slot, a key with an exclamation mark shows up on my dash. I've searched all over the internet and couldn't find a solution. Can you guys help me out please?
  2. JC91006
    16,482
    8,399
    When you say "keyless entry works", do you have to press the remote button?
    Is your 2007 a base model or does the door handles have a little rubber piece you can press (this locks the doors)
    Chow and ILuvMyPriusToo like this.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    OP, those are the first questions to answer if we are to help.
    Chow likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,226
    5,910
    Columbia, SC
    Under your steering wheel, on the dash is a small button labelled KEY. This enables/disables the SKS function. The button must be in the out position for the key to work from your pocket. If the button is in the "in" position, it disables the SKS function and you have to insert the fob into the slot.
    Chow likes this.
  5. Chow
    Chow Junior Member
    United States
    Yes, my Prius has the rubber button on the door handle. No, I don't have have to press the remote button I can just leave my key in my pocket. The SKS button under my steering wheel is in ON position.
  6. Chow
    Chow Junior Member
    United States
    Yes the SKS button is in the out position that's why I'm able unlock/lock the car with the key in my pocket, but I can't start the car without the key in the slot.
  7. JC91006
    16,482
    8,399
    There is a receiver that's in the center console that controls the ignition start. Maybe the wires got loose. You can remove the rear cup holders and you'll see the SKS receiver in there. It's the size of a credit card. The rear cup holders just pop off with a little bit of force (or use something plastic to pry it off, that way it won't scratch it)
    See attached picture, it should be inside after you remove cup holder
    #7 JC91006, Jan 4, 2020
    SFO and Raytheeagle like this.
  8. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    Another thought before you start pulling things apart - have you tried replacing the battery in the remote?
    fotomoto likes this.
  9. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Wondering if you found the issue.
    Yes, best DIY first action, replace the FOB battery.
    FWIW, perhaps the sensor on the brake pedal; in other words, if your step on the brake pedal firmly will the car start with the FOB in your pocket?
  10. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    It is possible, since the car is new to you, that the remote you have is a replacement and not programmed fully and correctly to the car. If simple troubleshooting does not solve the problem, I would take this up with where ever you purchased the vehicle.
    If an original key is not available, it may require a Toyota dealer or licensed auto locksmith to have new remotes properly seeded to the car (in which case you should have two done so you have a back-up if you ever lose one. Reseeding is a costly procedure.)
  11. jjmerp
    jjmerp Junior Member
    49
    22
    Ohio
    The Smart function might be on, but when you insert the key fob it will deactivate the smart function. Press the smart button In and press again to turn on smart function. 20200106_213639.jpeg
  12. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    Where do you get this idea? It is certainly not supported by the excerpt from the manual that you attached.
    The "Key" button is simply a deactivate function. When the button is in the "In" position SKS is deactivated. When the button is in the "Out" position, SKS is activated. There is no change to this regardless of whether the key fob is in or out of the key slot.
    As pointed out in the manual, the primary purpose of the deactivate function is for when the car will be locked up and not used for an extended period of time. For example, when parked up at the airport. The purpose is to reduce the current load while the car is in "stasis".
    The best advice so far is that from JC to check the SKS receiver at the back of the center console (and also the connectors and wiring back to the ECU, which are also candidates for failure). This is the one used to detect that the key fob is in the car. If the car cannot determine the key is in the car, it will not start.
  13. Chow
    Chow Junior Member
    United States
    This is what I am afraid of... I bought this car from a private party... looks like the key is not the original key of the car. Thank you
    I tried tightening the wires and it still didn't work... I'm afraid ILuvMyPriusToo might be right, I might not have the original key of the car. But thank you anyway.
    Already tried that and still doesn't work. but thank you anyway
    #13 Chow, Jan 7, 2020
  14. JC91006
    16,482
    8,399
    If your car works to lock and unlock your door using SKS functions, then it'll work to start your car. If the car is not starting, the area of fault is in the receiver mechanism inside the center console.
    If it's a problem with the keyfob itself, you won't be able to use the functions to lock/unlock your doors
  15. Chow
    Chow Junior Member
    United States
    So all I need to do is replace the receiver? What is the receiver called? I’ll try to find it online.
    Thank you so much for your help
  16. JC91006
    16,482
    8,399
    That's not guaranteed to work, as there are other places (wiring). But that's the cheapest and easiest culprit to change out first. Any junk yard or person parting out a Prius will have this part. I don't know the exact name for it though
