Keyless remote entry doesn't work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hmidnight58, Feb 20, 2015.
  1. Hmidnight58
    Hmidnight58 Junior Member
    WV
    I have a 2005 Pruis and the remote entry does not work. Changed the battery in the remote and I still have to put the remote key in slot to start the car. Been working fine for ten years. Thoughts. Thanks
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    Does the red light on the fob blink when you push the buttons? You might have a stuck button. The rubber caps get brittle and don't release sometimes.
    #2 nh7o, Feb 21, 2015
    49,384
    how old is your 12 volt?
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Check that your key button under the steering wheel is off (out). So that keyless system is on. If it’s, try putting it in and then back out.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Do you have another remote ?
    It is possible that your new battery is bad......or that it is not making good contact.
  6. bisco
    49,384
    are you stepping on the brake hard enough?
