Keyless remote poor range
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jetman, Jun 15, 2017.
  1. Jetman
    Jetman Junior Member
    PA
    My keyless remote range has diminished. The red light goes on when I push the button but I have to be literally 2 feet from the car to unlock the door which pretty much defeats the purpose of a keyless remote. I figured the battery might be dead so went to the hardware store and got a brand new 1632 but has not made any difference.
    I have a 2013 Prius II so it only opens the drivers side door when I touch the handle. When I'm with my wife it's nice to use the remote to unlock her side especially when its raining etc. My spare remote is doing the same thing so I think my 12V might be going? Its original 12V. It's starting to irritate me so I will have to take it to the dealership and test the battery. I have a 2 so it doesn't have the big screen that shows battery life. I keep my key 10-15 feet away from the car inside so don't think thats the problem.
    52,755
    if it's not the 12v, find someone with a volt meter, and test the new fob batteries. they should be 3.3v.
    dorunron likes this.
  3. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Replace the FOB battery
  4. harrysprius
    harrysprius Active Member
    277
    126
    Nashville, TN
    Mine only works out to about 5 feet. If a battery fixes it let us know please. Could be you bought a low battery. Maybe been sitting around a long time? Thanks!
  5. Jetman
    PA
    I already replaced the battery with a brand new 1632 in one of the remotes. Both of them are not working properly so I'm thinking its the 12v. I will go to the hardware store and see if they have a volt meter they can test the fob if it's putting out 3.3v and if it is then it's the 12v car battery and will go to the dealership and test that. Ill let you guys know one way or the other.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    A lot depends on the brand of battery you bought and where you bought it from. I recommend the Duracell battery. You should have a range of at least eight feet. I can lock and unlock our doors on our 2013 from inside the house with our keyfob and "fresh" batteries.
    Also do recommend you check the voltage of the 12 volt on the Prius. If it reads less that 12.3 volts after sitting all night with the Prius OFF, it would be a good idea to change that battery also. Yeah, it's expensive but it will help.
    Use a digital type volt meter that can be found at the dollar stores to measure the voltage. You don't need an expensive Fluke meter for that work.
    Peace,
    Ron (dorunron)
  7. Jetman
    PA
    Key Fob batteries test good. I took the FOBS to a hardware store and they had a FOB tester and it does the same thing you have to be real close to get it to work and it says replace battery even though we tested the brand new battery and its good. So looks like something is wrong with both of my FOBS which is quite weird.
    My 12V at the jumper lead says 12.5 so battery seems okay. I ordered a CTEK 3300 and will charge it overnight and see if anything changes.
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    Remote range extending trick, touch the remote to under your chin when pressing the button.
  9. dorunron
    3,318
    1,105
    Houston, TX
    Just for grins, what brand of batteries are you purchasing for your keyfobs? Where are you buying said batteries?
    Ron (dorunron)
  10. Jetman
    PA
    I use energizer. I just found out that it may not be the battery though. I went on a couple day vacation and when I got back to the car at the airport the range was magically extended. I think I my problem is my keyfob is too close to my car when I am at home. I park out front and have very large windows and even though the Fob sitting on the counter is 10+ feet away it was still communicating with the car and draining the fob. So I put my keys in a cabinet now further away and I will see if that will do the trick. Thanks for the replies! I hope this fixes the problem.
  11. TheBippi
    TheBippi Junior Member
    36
    16
    2017 Prius c
    Hopefully this isn't that joke from a few months back where we have to place all our electronics in the microwave to block them from listening...
  12. Jetman
    PA
    That was it, it has been a week and the range is still strong with my keys being in the upper kitchen cabinet. Well at least I got a new Ctek 3300 smart battery charger now.
  13. Jetman
    PA
    The key started not working again. The perm. fix seems to be improper grounding. If you are having problems with your Gen 3 please search youtube below. Mine is still having problems but it is something else to try. Next step is new 12V battery and if that doesn't work brand new key fob on amazon for 165$. lol
    2010 Toyota Prius Remote Short Range Solved
    vid by Oleg Khriswell
    #13 Jetman, Nov 12, 2018
