Keyless Remote - Store Without Battery?
Discussion in 'Gen 3 Prius Main Forum' started by bilofsky, Jul 3, 2012.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Is there any reason to leave the battery in my spare remote, which will probably sit in a drawer for years?
    Taking the battery out will ensure that the remote will work when needed without a quick trip to Radio Shack. Unless, of course, it does just the opposite?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    That would work. The battery has a shelf life of about 11 years.
    Unless of course, you broke it removing or replacing the battery. ;)
  3. ETC(SS)
    7,335
    You may want to consider removing the battery and storing it inside the vehicle somewhere.
    What I've found is that you can tie-wrap the keylet to an undisclosed exterior location, and store the remote sans battery inside the car, hidden deeply.
    That way....if you lose your primary fob/key when you're far from home, your car does not become a 3500# paperweight until you go and get the second fob.
    Lotsa different ways to do it, but to answer your question: Yes. You can increase the life of the fob battery by removing it.
    Worth doing?
    YMMV.
