Kia hybrid crossover aims for Prius-like mpg
Discussion in 'Hyundai/Kia/Genesis Hybrids and EVs' started by cjecpa, Feb 11, 2016.
  1. cjecpa
    cjecpa Member
    160
    58
    m.wynn and TonyWilkey like this.
    49,492
    good luck to them. as many are want to say here; if it's anywhere close to prius mpg's, is roomier, more comfortable, better looking, more reliable and cheaper... i'll buy one.
  3. cjecpa
    cjecpa Member
    160
    58
    A lot of torque
    49,492
    and that's another thing. so may areas where toyota is missing the boat.
  5. cjecpa
    cjecpa Member
    160
    58
  6. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Well they aren't the first! Ford try it and fell short they where making hybrid way before KIA! Be nice if they did!
  7. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Looks like an Audi Suv from the side! Looks nice.
  8. cjecpa
    cjecpa Member
    160
    58
    Obviously it will be only FWD with that mileage and the same wheel base as the 2016 Prius. Wonder if rear cargo room is the same as the ECO?
  9. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  10. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    good question but EPA cargo space spec has muddied the comparisons. If possible check out other countries like Japan/EU specs to get real numbers. Unfort looks like Canada has gone over to USA methods so that way to compare is out.
  11. cjecpa
    cjecpa Member
    160
    58
    Actually in the video above it looks rather narrow even the back pack looks like it take up a lot of room. Smart rather then offer a hatchback Hybrid call it a CUV since that segment is hot. Actually this manufacturer is bringing out two hybrids and Ford announced a new Hybrid to compete against the Prius will be built.
  12. bisco
    49,492
    whats wrong with cmax?
    MERGED
    white trim? they must not read priuschat.:cool:
    #12 bisco, Feb 14, 2016
    San_Carlos_Jeff likes this.
  13. cjecpa
    cjecpa Member
    160
    58
    Are These Ford Motor Company's Four All-New SUVs? -- The Motley Fool
  14. bisco
    49,492
    ya, there'as a lot of if's, and's or but's in that article. and a lot of guessing.
    a wall street JOURNAL report says that ford is planning to build a new hybrid said to be a 'PRIUS FIGHTER'. here we go again.:rolleyes:
    isn't that why they built the cmax?
    motley fools think it's going to be a crossover because that's what everyone is buying. well maybe, who knows?
    but can you build a 50 mpg crossover? not so far.
  15. Trollbait
    11,561
    Hyundai's system may have a cost advantage in using smaller motors to get things done.
    "Here are two prominent perspectives on this growing competition between hybrid types. From John German of the International Council on Clean Transportation (ICCT): “The Toyota/Ford‘s power-split hybrid is the most efficient hybrid design out there, but it’s inherently expensive.” The problem is the fixed torque split between the drivetrain and generator from the engine. For part-load operation, you can bias the power by adjusting rpm, but for maximum power the generator must be oversized to handle the engine’s power (plus a margin), while the traction motor is sized to handle the combined output of the generator and the battery pack (plus a margin). So you wind up with two very large motors.
    “A P2 can get close to a power-split’s efficiency—about 90 percent—during city driving, and you can match them on the highway,” German continued, “but at significantly lower cost, especially with a small, high-power lithium-ion battery (way tinier than its nickel-metal hydride alternative yet powerful enough to satisfy a hybrid’s needs). The Achilles’ heel of the P2, or parallel hybrids, is bump-starting the engine. Early systems that eliminated the torque converter didn’t work well. But more sophisticated algorithms are changing things.”" - 2017 Kia Niro Hybrid Prototype First Drive Review
    First I heard in the link about a Niro PHEV. Makes sense if it was codeveloped with the Ioniq.
  16. usnavystgc
    3,159
    989
    Tucson, AZ
    Didn't Aerosmith write a song about competing with the Prius? I think its called "Dream On". :)
  17. cjecpa
    cjecpa Member
    160
    58
  18. bisco
    49,492
    aim high, gravity always wins.
  19. cjecpa
    cjecpa Member
    160
    58
