Knee hits center console in Prius Prime
Discussion in 'Prime Accessories and Modifications' started by Chris MM, Dec 21, 2018.
  1. Chris MM
    Chris MM Junior Member
    2018 Prius Prime
    I tried to position my car seat and steering wheel but my right knee keeps pushing against the center console. Very uncomfortable, especially in long rides. I use a thick towel now over my knee which helps. I keep reading on the internet about people having the same problem. I wonder how people in PriusChat (if any) have the same problem and how they solve it.
    52,382
    someone taped some foam there. do you have long legs?
  3. Mannn
    Mannn New Member
    Toronto, Canada
    2019 Prius Prime
    Upgrade
    i have the same issue as well... need to have a towel handy for that reason.. i don't understand why Toyota makes such poor design on that part
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    There's a good chance you're taller than the shorter (Roughly) ~5' 5" Japanese engineer that built the Prime.
    Rob43
  5. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    as previously posted to Prius Chat forum:
    Raytheeagle and Rob43 like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Sounds like you need to raise the front of the seat to better support your thigh or else move it back to lower your knee. My seat blocks my knee from going that far to the side.
  7. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    same problem here. its not going to get fixed. dash is impossible to modify easily, my leg isnt going to get shorter either.
    kinda annoying actually, one of my only gripes about the prime.
    i can make a knee pad to wear for longer trips i guess.
    my left knee also rubs against the armrest... which has a sharp edge too.
    i will make a pair of knee pads. :eek:
  8. jerrymildred
    11,517
    14,157
    Tampa, FL
    How close are you guys sitting to the steering wheel that your knees come up and over the raised sides of the seat? Also, if you're not already aware, the steering wheel telescopes, so if it's a problem with reaching the wheel, you can extend it. I know that I'm slightly inseam challenged, but I can move the seat back so far I can't even come close to reaching the gas and brake pedals.
    Also, you can raise the front of the seat by itself and get it up against your thigh for support.
    GTD_XW30 likes this.
  9. GTD_XW30
    GTD_XW30 Junior Member
    Chino Hills, CA
    2020 Prius Prime
    Precisely! I’m 6’2ā€, found my sweet spot. Seat 90% back and front slightly tilted, steering wheel is about 1.5 inches from default. My side of the knee is resting on the console and does not bother me.
    jerrymildred and Old Bear like this.
