Knocking and rattling noise on low speed 2012 prius
Discussion in 'Gen 3 Prius Technical Discussion' started by Chuba, Aug 16, 2021.
  1. Chuba
    Chuba Junior Member
    45
    Nigeria
    Good day every one.
    My 2012 prius makes knocking and rattling noise when ever the engine starts and I'm on stand still or moving slowly. If I'm speeding the noise stops. I don't have any check engine light on. Scan does not show any issue.
    I have changed the 4 plugs.
    Cleaned the injectors, Intake manifold, throttle body, egr valve all cleaned. After cleaning all these the knocking and rattling sound remains.
    It's comes one at slow speed only if the engine is on and hybrid battery charging. If I match my pedal hard and speeds the sound stops.
    I noticed that this does not happen on cold start. It happens when the car is warned up.
    When I removed the inlet manifold to clean it. I looked inside the engine. I noticed that all the inlet and outlet valves are carbon coated expect the 4 cylinder. I noticed that the 4th cylinder inlet and outlet valves are half inch clean on top.
    Please watch the video link below. It shows exacting what my car does. The video is not mine but exact the same issue.
    Please house what could be the proble and its solution?
    I changed the transmission fluid one and half years ago.
  2. Chuba
    Chuba Junior Member
    45
    Nigeria
    See what cylinder number 4 inlet and outlet valves looks like. U will notice its half inche clean on top. Where as other are black though out.
  3. Chuba
    Chuba Junior Member
    45
    Nigeria
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    When you had your manifold off for cleaning, did you replace the PCV valve? A malfunctioning PCV valve could be the cause of the rough running at idle/low speed if it's stuck open, letting in crankcase vapors and loosing vacuum, which affects low rpm performance more than higher rpm performance, when the valve would be open anyway.
  5. Chuba
    Chuba Junior Member
    45
    Nigeria
    Thanks for your quick response.
    I removed and cleaned the PCV valve. Forget to add it in the original post. The pcv valve is still as good as new. Checks as normal.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,536
    6,617
    Texas Hill Country
    No video but if it sounds like this it is likely a head gasket since you have replaced the other parts.
  7. Chuba
    Chuba Junior Member
    45
    Nigeria
    Thanks for your response.
    I don't think it's head gasket because my coolant doesn't short and the engine oil does not show any signs of water in it.
  8. Mendel Leisk
    41,925
    How many miles on it?
    If 150,000 miles or more, and the Exhaust Gas Recirculation circuit and intake manifold has never been cleaned, I too would suspect head gasket failing. This is happening regularly with 3rd gen Prius (like yours), and very often it's at cylinder one, sometimes cylinder two.
    A leak-down test would help immeasurably, to diagnose determine head gasket condition, and pinpoint where-and-how if it is leaking.
    More info about EGR cleaning in link in my signature.
  9. rjparker
    10,536
    6,617
    Texas Hill Country
    Many people have the same initial response and it turns out to be the head gasket. The coolant leaks small amounts at first and exhaust gasses replace it. Driving like this will make things worse including engine replacement. Other missfire sources like plugs, coil, injectors or stuck open egrs (not clogged) will not quickly clear up and will last long enough to throw codes. A borescope analysis is often definitive as the leaking cylinder will be cleaner than the rest.
    Denial is the first stage of acceptance. In this stage, individuals believe the diagnosis is somehow mistaken, and cling to a false, preferable reality.
  10. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    Hmmmm.
  11. El chingon
    El chingon New Member
    Monroe NY
    Have the same issue, no codes. cleaned the intake manifold,
    Cleaned the egr valve
    Cleaned the cooler
    All three items were not to badly clogged.
    Changed the pcv valve
    I did find I piece of the metal catalytic shield loose and it came off, that helped some what but still vibrating at low speed only
    I also changed all four plugs
    Can someone chalk the pics of the cylinder shaft and tell me what you think
    My last resort is to change the injectors
  12. Mendel Leisk
    41,925
    How many miles?
  13. El chingon
    Monroe NY
    150k,
    Today the noise got louder when going slow in heavy traffic.
  14. whazzup
    whazzup New Member
    16
    Yup, same issue here with my 2013 with 134000 miles. Ended up being the head gasket.
