knocking noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by IBGPRIUS, Mar 23, 2012.
  1. IBGPRIUS
    IBGPRIUS Junior Member
    I have Toyota Prius 2006 with about 58k miles. For the last 12-16 months I encounter the following problem: when I press brakes, I hear nocking noise. It doesn't happen every time, but when it does it only happens when I press the brakes. Once I brought my car to a Toyota dealer and waited for an hour until my car was taken for a service. Mechanic found no noise. I tried to produce this noise but my car didn't want to cooperate. I don't see any messages on a display screen. It happens with power on/off and pressed brakes.
    Is anybody know what the knock is and how to get rid of it?
    :confused:
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Mods, pls move this to Gen II Care, Maint...
    The brake accumulator pump makes a ratcheting-sound, like a burst of rounds from submachine gun, and such noise is normal. Are you saying that instead of that ratcheting sound, it is something else? Does it sound like a bark?
    http://priuschat.com/forums/gen-ii-prius-technical-discussion/19051-my-brakes-barking-me.html
    The very bad news is that you are way out of warranty for any brake system problem, and any repair at a dealership will be very expensive if it involves the actuator.
  3. Volignyt
    Volignyt Pro Cleanse
    ny
    I have bought a 1996 Renault Clio and there is a knocking noise under my feet when I turn a corner.
    Pro Cleanse
  4. Dalton Warren
    Dalton Warren New Member
    Utah
    Hey guys new here how do I start my own post anyways I have an 07 Prius with a rattling or knocking noise can't tell if it's engine or transaxle only check engine light codes are po300 po301 P0302 po303 PO 304 changed spark plugs and coils and new fuel injectors 2800 miles ago took each spark plug out and all but cylinder three were all brown and cylinder three was pure white like it came out of box but could tell it was sparking stumped on what I should do please help
  5. Dalton Warren
    Utah
    Also car has 305000 miles on it
