knocking, rattling, heavy shaking when gas engine start cold or when it hot
Discussion in 'Prius c Main Forum' started by papah, Apr 6, 2025.
  1. papah
    papah New Member
    washington
    2016 Prius c
    when the electric motor start the gas engine, there is a rattle and vibration that happens for couples of seconds and goes away. a knockings or ratcheting or grinding sound like. it's seems it coming from the passenger side or some sort. this happens when the car start cold or sometime when the car is hot, sitting a parking lot and the electric motor start the gas engine, i will hear this sound and vibration. there are times, if i stop at a red light or stop , and light turns green, i press the gas pedal, the car will rough idle or starving or choking, sputtering or loss of power symptom, after that episode it will start running normal. There is no engine light or ecu codes.
    have you experience this before, how did you fix it.
    Your guidance and wisdom is welcome.
    2016 prius C
    thank you.
  2. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,499
    SacTown, Ca
    How many miles and has all required OEM maintenance been performed; per OEM manual?
    You should have pending P0300 misfire code, if you scan the car.
  3. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Spark plugs, coils, air leak, throttle, fuel and more.
    If you had taken readings while the engine was running, it would have given a more detailed explanation of the engine rattling.
    A visual inspection through the spark plug wells inside the combustion chambers for coolant leakage using an endoscope is also applicable. In the morning on a cold car.
    James Analytic likes this.
  4. Mendel Leisk
    40,586
    What’s the miles?
    Prius c is more-or-less a gen 2 engine IIRC, and nowhere near as prone to head gasket failure, but could happen.
    Check codes. If there’s a specific cylinder misfire code (denoted by P0301 through P0304), swap coil/plug from offending cylinder with another, see if code changes accordingly, to confirm or eliminate it’s coil/plug problem.
  5. papah
    papah New Member
    washington
    2016 Prius c
    the mileage is 230k no engine code or hybrid code.
  6. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Consider purchasing diagnostic tools.
    These can be special programs for a laptop, OBDII adapters, cables-transition devices. A phone with programs and adapters for a phone can also be used.
    They will help in case of diagnosing errors that suddenly appeared.
    Gen2 OBD2 app review | PriusChat
    The choice is yours.
    It is better to do this preventively than to run around a faulty car later and ask on the forum what happened.
  7. papah
    papah New Member
    washington
    2016 Prius c
    hi? i used the dr prius app to scan it.
  8. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Each application has its own capabilities, pros and cons.
  9. papah
    papah New Member
    washington
    2016 Prius c
    hi? i am still experiencing this problem, i am working on change the injectors to see if this help solve the shaking.
  10. bisco
    51,155
    have a leak down test performed, you probably need a head gasket
  11. James Analytic
    304
    46
    Michigan
    They are like the 1.8L Gen 3/4/V engine design being that the Prius C 1.5L has the dreaded EGR and related Intake Circuit. Thankfully not the PCV Valve design placed down below that can use a reroute.
    I'd suspect by the sound of the situation, might be like the hybrid 1.8L design and need the Intake, EGR and PCV Valve circuits inspected and more than likely replaced or more cost effectively if can... cleaned. The sooner the better. Good to check like noted prior in regards to fuel and fire parts as well.
    #11 James Analytic, May 23, 2025
  12. James Analytic
    304
    46
    Michigan
    Have you cleaned the Intake and EGR Circuit at least? Like the EGR ports on the intake and the EGR Valve and Cooler at the very least yet or throughout it's life routinely? Guessing is a must do religiously like the water pump and thermostat on the later gens.
    I'm revisiting slightly the Prius C engine conversion so to swap into a Gen 2 as well as parts interchange. Mainly will have the electric water pump to deal with additional circuitry to include, though appears far easier to use a modified slightly gen 2 intake so the water pump fits and use the gen 2 exhaust so completely exclude the EGR circuit.
  13. Mendel Leisk
    40,586
    That’s maybe all true, but there are precious few Prius c head gasket failures here. Maybe some differences at play, or Prius c owners are just a resourceful/stoic lot, lol.
  14. James Analytic
    304
    46
    Michigan
    Lol. I have no clue. I have yet to read into the Prius C much other than interchange and doing the engine swap. Are the Prius C making it into the 350-500K club reliably?
    I know the regular gen2's seem to and I've worked on ones above 300k at least with way better sounding engines than the 260K one I found with a seemingly dead cylinder 1 plug and weak cylinder 2 plug along with other almost 300K tickers. For some reason I assumed the Prius C's engine weren't doing so great since I've not seen many, or any, over 300K ones like the gen 2's or even the gen 3's for that matter. Any scoop?
