Knocking rattling noise 2012 Prius v it is still a lowercase v for the Prius v wagon, not an upperca
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Dain Hill, Feb 6, 2017.
  1. Dain Hill
    Dain Hill New Member
    South Carolina
    Hey guys. I know there's quite a lot of threads about this issue. My Prius v it is still a lowercase v for the Prius v wagon, not an uppercase. Only the 2010 Prius used uppercase Roman numerals for model designation is making knocking or rattling noise every morning before I go to work. Sometimes it happens other times it doesn't. Was there ever a initial fix from Toyota on this problem? Is it something I really need to worry about? The temperature here right now only gets low of 30 degrees right now in the morning. It's similar to issue here.
    Loud engine sound at start-up | PriusChat
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    How many miles
    How well maintained
    How often you check fluids
    Do you do anual Toyota or recognized shop inspection
    What are your usual routine driving
    Do you have any error codes
    Or have in the past
    How you have any major repairs done before
    And a lot more
    When you coming to this site
    Give as much information you can
  3. Air_Boss
    Air_Boss Senior Member
    3,917
    1,069
    New Yawk
    Important to note that most who report experiencing the knock/rattle-at-startup do not experience it regularly, purely a rare anomaly.
    I've had it occur once in five years with the 2012 v Five, and that was very early on when I inadvertently cycled the START button through start-ready-off-restart, likely resulting in leftover unburned fuel in the intake.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    And thus if it is happening almost every morning, it should be checked out.
    Starting with pulling the dipstick and checking the oil level. ;)
