Knocking Rear Spoiler
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Harters, Mar 15, 2021.
  1. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    I have had a slight intermittent knock from the rear of my Prius for a while now, but yesterday I took the car out for the first time in ages and it has gotten worse.
    Initially I always thought it was the retractable rear roller, but yesterday it would make the noise when I closed a rear door. From that I have traced it to the rear spoiler, if I lift it a little and let go it knocks from what it seems, to be on to the edge of the small vertical rear window on the tailgate.
    I took off all the rear trim expecting one of the bolts holding the spoiler on to be loose, but they are all fully tight. It may be some flex in the underside of it.
    Has anyone taken off the spoiler or would know if its a simple as undoing 5 nuts or is there more to it?
    I am still within the 5 year warranty, but not sure if this would be covered, I don't think they could say its trim as the spoiler is part of the car.
    Any advise appreciated.
  2. Semmerket
    Semmerket New Member
    Brazil
    Hi Harters,
    I have the same spoiler rattle problem. Did you find a solution to it?
  3. Harters
    335
    424
    UK
    Excel
    Kind of... I took all the trim off the inside of the tailgate and checked the fixings and they were all nice and tight. Also checked the wiper motor cables etc. and everything seem tight. I managed to wedge a strip of dense foam between the underside of the spoiler and the vertical glass and it stopped the knocking..... but I still have the noise that I can hear in the car, so I think that must have been a red herring.
    It is so difficult to locate. I have sat in the back of the car with my partner driving and I just can't seem to locate where it is coming from, although it does seem to be coming from the passenger side area (UK here, so Driver's side if in US) and mainly when it's cold and when the car goes over certain kind of bumps.
    If I didn't love the car so much it would really get to me, so I'm not going to lose sleep over it. I may get my dealer to look at it when I take it in for its service in March.
    Mambo Dave likes this.
  4. Stangar
    Stangar Active Member
    174
    173
    Palmdale, CA
    I know this problem or should I say this is how it was fixed on my friends car. You think the spoiler is bolted on tight. However, those bolts are "looser" than you think and can be further tightened to eliminate noise. The problem is the material/plastic under the bolts that have deteriorated and diminished from the innumerable number of times the hatch has been closed/slammed. Put some more torque on that wrench!
  5. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    I have this exact same problem. Noticeable at highway speeds and annoying. If I have passengers and have the radio down its down right embarassing. Makes the car sound cheap.
    Mine is a Prime BTW but it still does it. I first thought it was a loose license plate. Tightened it down, even bunched up 3M tape under it to secure it better. Nope. Then I thougth it was the cargo cover, I tried driving with it open, closed, removed, nothing.
    The Prime has no rear wiper. I guess I'll have the spoiler area checked (not that it really has a spoiler, its more of an edge)
  6. Harters
    335
    424
    UK
    Excel
    I tried lightning the bolts, but they were very tight and the sound does seem to be coming from within the cabin.
  7. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    It’s a persistent only and mainly at highway speeds for you guys right? I don’t really hear it ever driving around town - but as soon as I get on the highway it’s “tap tap tap tap tap tap”…. i just turn the music up louder but when I have passengers I can’t really do that - and it’s so embarrassing. I make excuses like “sorry that must be such and such rattling I didn’t get to it yet” Etc
    never thought it could the spoiler
  8. Harters
    335
    424
    UK
    Excel
    No, mine is not persistent. I usually only every hear it going around town and just when the car hits a certain kind of bump in the road.
    The only time I would hear it on the highway was if again it hit a certain kind of bump. Around town it seems to be not when the car drops into a bump, but when it is coming out. I initially thought it was the loose rear shocker mountings that some people have had fixed, but mine are rock solid.
    Once the temperature warms up, the problem is goes away.
  9. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Now that’s odd. Once the temp goes up it goes away means something is possibly expanding or the opposite.
    Could it be a worn out exhaust hanger that as it gets hot begins to stretch, thus allowing the exhaust to sink down a little in the location it’s making contact which causes the noise? Just speculating
  10. Harters
    335
    424
    UK
    Excel
    It definitely sounds like its in the cabin, but no amount of jumping in the car and getting it to bounce as if it's going over bumps can get the noise to start.
  11. Mendel Leisk
    38,735
    There was another issue: some loose bolt on the rear suspension, on 4th gen. Not sure if it applied to Primes as well.
    Harters and Storm88000 like this.
  12. Stangar
    174
    173
    Palmdale, CA
    I've got another idea! Have you checked your fancy license plate frame? I used to have an Accord that had a rattle and the license plate frame was the culprit. It usually only happened on large bumps.
  13. Harters
    335
    424
    UK
    Excel
    I do not have a fancy license plate frame. Like most cars in the UK it's simply stuck directly to the car with double sided tape.
    I will get there one day...
  14. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    ^ me either. No license plate frame all. I removed the dealer one the day I got it. Should possibly try adding it back to see if it makes a difference almost…. The noise is quite embarrassing..
  15. Harters
    335
    424
    UK
    Excel
    UPDATE:
    I have found the culprit and I don't know why I did think of it before.
    It turned out to be the tailgate catch and I cured it by simply wrapping a small length of electrical insulation tape around the loop that the catch engages with and voila the noise is gone.
    I cannot believe how different the car feels without hearing the clicking and I didn't realise how much it was doing it until it wasn't there anymore :)
    Mambo Dave and Storm88000 like this.
  16. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Forgive me but what exactly, or where exactly is that? Any chance you can take a photo of what you did and where?
  17. Harters
    335
    424
    UK
    Excel
    Just as you open the tailgate, I guess you may call it the slam panel? E2D87E3E-44DE-4E42-86BE-D1B28599CE36.jpeg
    dbstoo, Storm88000 and Mambo Dave like this.
  18. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Okay got it. I’m going to try it right now. Just roll some tape on it ?
  19. Harters
    335
    424
    UK
    Excel
    yes I think I did 2 turns, anymore and the catch won’t unlatch cleanly. If you do too much just try a bit less.
    Storm88000 likes this.
  20. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I shall find out soon if it worked. Leaving in about an hour
