Knocking Sound on 2018 Prius Three
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Daniel Dang, Feb 17, 2022.
  1. Daniel Dang
    Daniel Dang New Member
    MO USA
    2018 Prius
    Hi everyone. Anyone know what is the knocking sound come from when it is on P and still running. When the engine turn on for keep the battery sometimes the knocking sound happen twice and come with the felling like someone knock the car from behind. Is there anyone know what is that sign?
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The Prius transmission does not really have a neutral or a clutch so to simulate neutral there has to be a careful balance of one of the MGs and the ICE. When the ICE starts there will be a small imbalance which will be felt as a surge. There is some play in the parking pawl which allows some rocking so whenever the iCE starts your Prius will rock and there will be a clunk from the parking pawl and the drive train. You can ignore it as it is unavoidable.
    JeffD
    bisco and Daniel Dang like this.
  3. Daniel Dang
    MO USA
    2018 Prius
    Thank for the information Jeff. It happens when I switch to Parking. Can I avoid it by switch it to Neutral and hand brake?
  4. jdenenberg
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When you turn off power the parking pawl will engage anyway. If you use the parking brake, the Prius will not rock when the ICE starts and your symptoms will be gone.
    JeffD
    Daniel Dang likes this.
  5. Daniel Dang
    MO USA
    2018 Prius
    Thanks. I will try this way.
  6. Mendel Leisk
    41,925
    How many miles on it?
  7. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    Will milage decide if there is a sound or not?
    Had an interesting sound situation, came in from a trip and when I got close to home, all of a sudden there was a horrible rubbing sound at the rear passenger fender, stopped to check and didn't see anything at first, then found a plastic piece at front side of bottom of rear wheel well had flipped sideways and was contacting tire. I have no idea what the piece was, or what it does, almost like a spacer piece at bottom of wheel well, just spun it back in place I think, but that cured that sound.
