Knocking Sounds when Turning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TonyPSchaefer, Jun 30, 2012.
  1. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Priapus has taken on a new habit. When making turns at any respectable speed, there's a very noticeable knocking sound. I've had the windows rolled down and can't tell whether it's coming from the right side or the left. I'm pretty sure it's coming from the front.
    I just put him up on blocks and rolled under to check out the front suspension, turning mechanism and anything else I can see. It wasn't long before I realized that I have on idea what I'm looking at nor am I likely to recognize any problems if I saw it. Having said that, nothing looked broken or dangling.
    He's due for a 100,000 mile check-up. Since I'm heading to the dealership, it would be easy for me to have them look at it.
    Does anyone have any thoughts beforehand?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Bad CV joint? Do you see any torn rubber boots near the wheels?
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Usually a knocking sound while turning is a sympton of a worn CV (constant velocity) joint.
  4. TonyPSchaefer
    14,816
    2,498
    66
    Nothing looked warn or torn but I suppose that doesn't mean it's not worn.
    What can I expect to pay?
