Known "Noise Package" Needed?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Anam Cara, Aug 19, 2009.
  1. Anam Cara
    Anam Cara New Member
    New Mexico
    Yes, this is a brand new 2010 Prius... Purchased at a dealership in Colorado and driven home to New Mexico... On the trip home there was a sound at low speeds like a bushing rubbing emulating from the right side front... Granted, upon taking it immediately to my local dealership, the (hopeful) "fix" was installation of a "Noise Package" which I was told consisted primarily of felt and double-stick tape added under the dashboard) and additional lubing of the body,
    but if an immediate "fix" was for a known problem, shouldn't the original dealership have installed this "package"??
    Should prospective buyers of the new GIII Prius ask if the package is already installed, or has Toyota already added it to the assembly line process??
  2. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    If it's like a typical Technical Service Bulletin, TSB, these fixes are applied only to vehicles exhibiting the symptoms described in the bulletin.
    That is, there's no need to fix something that's not broken (and not exhibiting the symptom).
  3. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    Before you freak out, this is typical for all cars since forever... this is why dealers are supposed to do a "test ride" before delivery.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Did it work?
  5. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    On this topic - is there a place where we can obtain a listing of outstanding TSBs for the '10 Prius?
    1. Would be good to know in case specific issues arise.
    2. Would be good to know if a problem covered on a TSB is just beginning on your vehicle.
    3. Be good to have this as an owner - like Freedom of Information Act. And we're forearmed, if the dealer is not aware of a fix.
    I have an early-production V (#1628) - in case there's running changes etc that may be covered as well.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
  7. MikeDS
    MikeDS Member
    298
    Los Angeles
    Wow, thats a lot of dough to look at a list...
  8. jay_man2
    1,246
    143
    Manassas, VA
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Evidently there is a little known Chargedom of Information Act.
  10. DeanFL
    1,015
    355
    You guys hit it on the nose - what I meant was --- list the current TSBs here on PC. Wouldn't think that's a conflict of interest. I mean I'd like a bit more for my $28K than just a nice car....
  11. jay_man2
    1,246
    143
    Manassas, VA
    AllData is a free source to see the TSB titles, but you have to register to get access. And with every manufacturer there will be standard TSBs that provide information to the dealer, but aren't an issue for a customer; things like pre-delivery inspection instructions, fob programming instructions, etc.
    And last I looked, there was a little bit of a lag from the time a TSB was issued until it appeared on AllData's list.
    ALLDATA - Leading Provider of Automotive Repair Information and Solutions
  12. DeanFL
    1,015
    355
    Just looked at the site and went to register, until I got to the year of the car. The choices stopped at 2008. Huh? Perhaps the manufacturers do not release this info to the general public on newer models. ie - must pay for it thru their own web sites....
  13. jay_man2
    1,246
    143
    Manassas, VA
    I used the site a few years ago before you had to register, and they had a disclaimer about Honda not allowing access to TSBs through AllData. I guess everyone jumped on the bandwagon.
