Konig Heliums
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cfive, Jun 16, 2008.
  1. cfive
    cfive New Member
    CA
    Just to throw it out there... I recently read a post regarding lightweight/performance rims... but very expensive! here is a cheaper alternative... available in 15 and 16 inch diameters... i believe they weigh bout 10.1 lbs (15's) and 10.8 (16's).
    more colors available...
    i myself is planning to get their "redline" edition (1st pic)... w/c should go with my black prius!
    hope this helps!
  2. cfive
    cfive New Member
    CA
  3. GatorJZ
    GatorJZ Member
    285
    17
    What is the offset of the factory wheels? Konig is somewhat famous for making good to very good quality knock-offs of other manufacturers' wheels. Depending on the offset issue, this might be a very reasonable alternative to the expensive Volks.
  4. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Helium does not come in our bolt pattern (5x100) for 15".
    16" tires on the market are heavier than 15". I bet Helium 16" will weight less than touring ed 16" rims.
  6. a_gray_prius
    2,927
    782
    IL
  7. cfive
    cfive New Member
    CA
    yeah, its just for 16's ... unfortunate for others who are only looking at 15 inch wheels... but looking at the pictures on this forums... looks like 17's or 18's are the way to go, given that the prius body is kinda huge if ure looking at it from the side, having 17's or 18's (havent seen 16's with 45 series or 40 tires on yet) would look proportioned to the body. My 2 cents..
  8. thomatt12
    thomatt12 New Member
    61
    Those are definitely nice alternatives if you wanna set-up your Prius. I specifically like the bronze one. Looks good in my opinion.
    __________________
    The Toyota Nut
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    IMO it's not the wheel weight that kills us when we swap to larger diameter tires, it's the heavier tires compounded by a higher friction (higher RR) number. My 17's weigh the same as my stock wheels but the tires throw everything off and my milage suffers.
    Once they start coming out with some truely LRR 17" tires we'll have some real choices ro make. :)
  10. a_gray_prius
    2,927
    782
    IL
    I'd be willing to give up 4-5mpg if it meant I could put some Advan A046s (like on my other car) on my Prius. Unfortunately, they're 25lbs each which means 36lb/wheel.
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    If the wheels are 25lbs/ea then you'd be closer to 45lbs per wheel/tire combo. 17" tires are generally 19-23lbs/ea. :(
  12. jparrette
    jparrette Junior Member
    Cornwall, NY
    Where did you get the weights for the Heliums? Wheelweights.net lists the 16"s at 16.4 pounds.
    Also - SSR Type C's are designed for TRACK. They bend if you look at 'em funny. I'm sure the same is true for the Motegi Traklite. Unless you live where there are NO potholes (ie. NOT the northeast) I'd avoid these.
    I'm looking at:
    Enkei RS-M 16x7 (13.5 lbs) or
    OZ Ultraleggera 16x7 (14.8 lbs)
    Both at Tirerack.com. Any suggestions for light tires?
    John Parrette
    08 Spectra Blue Mica, Pkg 6 (on order!)
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I'm not sure which is more important between weight and LRR but I assume it is a combination of the two. The lightest tires I've seen where the General Exclaim UHP? tires. I don't know how they rate as far as RR though. If they are high RR then maybe a heavier tire with a lower RR would be better?
  14. a_gray_prius
    2,927
    782
    IL
    That's actually really good to know. I saw a guy with a modded Legacy GT running the traklites and they looked OK (though I don't know how long they had been on the car). I'll probably end up just buying the Volks for a few hundred more. Actually, I want new rims for my Evo, so maybe 2 sets of Volks ($4000, just for rims :eek: ).
  15. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    +1 totally worth it if they make the proper fitments in 16"
  16. asianguy80
    asianguy80 New Member
    San Gabriel, CA
    Just to let everyone know here are the actual weights on the rims straight from the website:
    HELIUM SILVER
    15x6.5 = 11.6 lbs
    16x7 = 15.5 lbs
    So they are a bit heavier then the Volk's ECO's.
  17. KandyRedCoi
    860
    SoCal/AZ/NV
    so what is the OEM offset and what offsets do these heliums come in???
  18. asianguy80
    San Gabriel, CA
    The stock offset is 45mm and the Helium's are 40mm
  19. KandyRedCoi
    860
    SoCal/AZ/NV
    that just may work...sweet thanx
  20. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    has anyone seen these wheels in a 5 lug? the design doesnt really allow for a 5 lug pattern, I am really curious how it looks.
