  1. dogclothesdude
    dogclothesdude Junior Member
    Littlerock, CA
    Hello All!
    After I removed the 12v (I had to charge it), my speedo went from MPH to KPH. I love doing a 100, but, I really need to get it back to MPH (no one said there'd be math involved to convert, LOL). I've looked in the book, ran thru all the settings adjustments but no joy. Any and all help will be appreciated. She's a '13 3.
    49,371
    not sure, but on the lift back, there's a button on the dash to the lower left of the steering wheel
  3. fuzzy1
    10,149
    From the 2013 'c' Owner's Manual, p. 188:
    Capture.JPG From the 2013 'c' Owner's Manual, p. 188:
    #3 fuzzy1, Oct 25, 2019
  4. Mendel Leisk
    38,644
    Yeah, so make sure it's not on one of the trip meters, say A or B, or distance-to-empty: set trip so that Odometer is displayed. Then press-and-hold trip.
    #4 Mendel Leisk, Oct 25, 2019
    fuzzy1 likes this.
  5. fuzzy1
    10,149
    Yes. If it is on either Trip meter, it clears that Trip meter instead.
    So I updated that post to display that whole page, to make it bit more clear. Or at least as clear as Toyota chooses to make it.
  6. dogclothesdude
    Littlerock, CA
    As you can see, it tracks the mileage in 'miles', and MPG. The speedometer as you can see, is in KM/H. I apparently did not make this clear in my OP.
    How do I reset the speedometer to MPH?
  7. bisco
    49,371
    maybe they mean the speedo, did you try it?
  8. DKTVAV
    DKTVAV Active Member
    510
    101
    - Change your right display to a different mode like Eco Mode.
    - Make sure it's "ODO" on top of the display, not Trip A or Trip B.
    - Press and hold the "Trip" switch on steering wheel to change to MPH.
    dogclothesdude likes this.
  9. Mendel Leisk
    38,644
    You basically have to pull over to do this, or be unsafe! 2010 Prius, there's a dedicated button on the dash: every push toggles the units. Once again, Toyota introduces new "feature". :mad:
    I can picture American motorists, just north of the 49th parallel, pulled over, leafing through their (700 page) Owner's Manuals. Or vice versa for Canadians.
  10. dogclothesdude
    Littlerock, CA
    Thank You!!
    Just went out and did it - all good now!!
  11. fuzzy1
    10,149
    Did the Owner's Manual snippet in post #3, with highlighting, not show up on your computer or device?
