L19 Harness where is it
Discussion in 'Gen 3 Prius Audio and Electronics' started by LovingLife, Feb 23, 2011.
  1. LovingLife
    LovingLife Junior Member
    75
    22
    Denver, CO
    From the Prius System Diagram document it shows Mute being on L19 harness on Pin 17 if I'm reading these correctly. I have all the Prius Manuals but I can't seem to figure out how one figures out where all these various harnesses are on the car. How does one go about trying to figure that out? A pointer to where is the L19 harness is would be appreciated?
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    There should be a drawing of the car in the wiring diagram that points out the L19 connector location.
  3. RodJo
    RodJo Member
    423
    56
    Boston
    L19 seems to connect to the Safety Connect Transceiver (note all the *8's in the diagram, including the mute wire). I don't believe your III has Safety Connect, so you will never find the connector or those wires.
  4. spiff72
    spiff72 Member
    184
    37
    West Michigan
    Here is a diagram showing the location if you did have it in your vehicle...looks like it would be in the area beneath the head unit/AC controls...
