LA Times on "keyless entry and ignition"
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jan 25, 2010.
  1. bwilson4web
    15,518
    Safety of cars' keyless entry and ignition systems questioned - latimes.com
  2. hill
    8,173
    Quote: . . . Introduced less than a decade ago on luxury models, . . .
    Luxury Models? Now THAT's a hoot. We've had SKS since '04. Yet our '06 Lexus STILL had a mechanical ket ... 75 year old technology. That still bugs me. So ... WHAT luxury car had them sooner than Gen II Prius' ??
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I believe the starter button replaced the crank and it was on the floor before the ignition key was invented. The Ford Museum video said the Model T had a starter in 1919. Never let the facts get in the way of a good newspaper story.
  4. bwilson4web
    15,518
    I drove a Model A in high school (long story) and the starter was on the floor.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Even the 54 Ford had one. Remember the cylindrical metal high/low beam headlamp switch on the floor? The 54 Ford starter was the same. -SOME- of them were mechanical in that when you stepped on it you shoved the starter gear onto the flywheel and the contact (on the end of the mechanical device) then fired up the starter motor.
    Ah, the "good old days"! ;)
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I have driven Jeeps with floor starter buttons.
    There is a reason that the starter buttons were put on the floor: Starting currents are very high, so you need a large switch mounted close to the starter. Modern starters use some sort of relay for this function, but in older cars the starter switch handled all of the current. This made for a big, stiff switch. Mounting the switch on the floor shortened the wiring run to the starter and also allowed the driver to use a foot to operate the big switch.
    Many cars used to have floor headlight dimmer switches for the same reasons.
    Tom
  7. pr4424
    pr4424 New Member
    57
    Washington, DC
    Corvettes have had them since the 2005 model year (which came out in 2004).
  8. hill
    8,173
    There you go ... still the same year as the (Gen II) prius ... which 1st hit the markets in late '03 I believe. I'd find it a streatch to call the vette a luxury car too. So what luxury car had 'em before the prius? I think some Lexus may have had 'em as early as the prius, but earlier? Maybe the author considers the Prius luxury!
  9. smartalec89
    smartalec89 The Official Alaskan
    133
    anchorage, alaska
    For the price many people consider the Prius a luxury car.
  10. PRPrius
    PRPrius Active Member
    327
    198
    Mercedes-Benz introduced the technology back in 2000 with their new S-Class. Toyota used the same set-up as Mercedes (heat sensor on the handle and black button to lock the doors. Infiniti started introducing the technology after Toyota with one major difference. The button on the door is use to lock and unlock the car; they also use a knob to start the car (they later started using a push button ignition). **Mercedes introduced the system with the push button ignition on the shifter.
  11. PRPrius
    327
    198
    Renault also introduce the technology for the 2000 model year! The system is called Reanult Card.
  12. Tideland Prius
    16,152
    So what the article is really saying is that people have become so lazy that they're not bothered to learn a new technology. IOW, "it's always been this way". Then there are those who learn only as much as they need to operate the car. They don't care that there's a variable setting for the INT mode for the front wipers or care that the "B" mode means engine brake (or heck, what the L and 2 means on a regular automatic).
    Remember how people were complaining about the parking assist on the LS (despite the fact that it's been improved over the original one found on the Gen 2 Prius)?? that's because they couldn't be bothered to read the manual and learn the system. "You told me it parks itself. It takes too long. It's a stupid system". Well if you learned how to position the car properly, you wouldn't have to make so many adjustments on the screen!
  13. qbee42
    18,058
    3,074
    Northern Michigan
    We need to start making people prove that they are competent to drive - and not just first time drivers. The roads are filled with people having no business behind the wheel of a car.
    Tom
  14. Tideland Prius
    16,152
    You're telling me. My friend doesn't care what the car has as long as it looks good on the inside. I really wonder how many of these features are for show (leather, moonroof, rear sunshade etc).
  15. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    I have the V with ATP and frankly, I have not even played around with the Parking Assist. My feeling is that if you can't parallel park yourself, you have no business driving a car.
  16. Tideland Prius
    16,152
    Tell that to anyone who has a MINI and bought the parking sensors LOL.
  17. hill
    8,173
    Man . . . what's WRONG with us! We'd pay for parking assist ... rather than an 89 cent set of metal curb feelers that simply grind against the concrete if you get too close.
  18. F512M
    F512M Member
    415
    Laguna
  19. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I miss the floor button for dimming the headlights :(
    Whoops, did I just date myself?
  20. qbee42
    18,058
    3,074
    Northern Michigan
    "Click...Click" - car just went by the other way.
    Tom
