Lack of Heated Side Mirrors in 1,2, and 3
Discussion in 'Prius c Main Forum' started by Mamiya 7II, Aug 24, 2015.
  1. Mamiya 7II
    Mamiya 7II New Member
    Massachusetts
    2015 Prius c
    I am looking at the C for my next vehicle. I am a little irritated with Toyota for only making heated side mirrors available in the 4. I want to buy a 2.
    My Corolla made the heated mirrors available in the LE model. I didn't have to go to the top of the line.
    Can I live without heated mirrors? I don't know. I have had them on my cars for as long as I can remember.
    I know not everyone needs them, but if you live where it snows, I consider them a safety feature.
  2. Mamiya 7II
    Massachusetts
    2015 Prius c
    .........That post is for the 2015 model. Maybe 2016 will different.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If I could I would rip them off my car and sell them to you, I would. It's a complete waste of money in sunny California. I am irritated Toyota forced me to pay for it in my trim level, along with the useless heated seats. :p
    All joking aside, heated mirrors should be an easy modification.
    Geo Dude likes this.
    49,492
    if you have to park in sticky sleet/snow a lot, they come in handy. i never use mine.
  5. Mamiya 7II
    Massachusetts
    2015 Prius c
    Hi Modem,
    I know many parts of the world don't need them and they would get forced into an "accessory" they don't need. I just wish I could get them without having to buy a 4.
    Modifications: I hate doing things to brand new cars. :(
  6. Mamiya 7II
    Massachusetts
    2015 Prius c
    Bisco, do you ever regret buying your C in the winter time?
  7. Paul Tergeist
    Paul Tergeist Junior Member
    TX
    I don't have a heated mirrors and I'm thinking about buying them. Can I just buy mirror glasses with heating (8796152E00/8793152E20)? Is it possible that there won't be wires to plug them to and I need to replace the whole mirror assembly?
  8. ChapmanF
    15,618
    That is possible, but you can just check your wiring diagram manual at techinfo.toyota.com ($15 for two days gives you plenty of time to look around and download whatever you think you might use) and see what you've got. For instance, my Gen 1 has no heated mirrors, but I happened to see in the diagram there is already a circuit for them in my fusebox ... the diagram shows which empty fuse slot it is, and which pin of the connector at the back of the fusebox it comes out on. I would only have to get the right terminal at the dealer, crimp it to some wire and click it into the harness connector, and lay the wire to the doors and up into the mirrors.
    Whether your situation would be the same, or maybe better (the wire to the doors/mirrors could be present already), or maybe worse (circuit missing in the fuse box?), you would easily find out by looking in your own diagram.
    -Chap
  9. dborn
    dborn Junior Member
    44
    Montreal, Canada
    2015 Prius c
    Canadian models, even base, come with heated mirrors. I guess that's why we call Canada the great white north! :)
  10. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    I've taken out a c2 nonheated mirror and a c4 heated mirror, and only difference is that the c4's mirror has the heating element stickered to the back of the mirror while the c2 just had regular mirror w/o any heating element sticker
    So you could probably easily find a aftermarket (heck with just a search of "prius c heated mirror" on ebay already found 1 & it also comes with turn arrows), and since the glass can be easily replaced/interchanged w/o dissembling the whole mirror assembly, the HARDEST and most time consuming part would be to run the wiring and finding power...and according to the owner's manual the DEF (mirror heater, rear window defogger, so that it turns on with the use of the rear defogger button) fuse, is sadly located in the engine fuse compartment and not in the driver's fusebox.
    #10 SwhitePC, Dec 2, 2015
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    Honestly, I don't know. I've read a DIY for installing LED blinkers on the mirrors and it was plug and play as Japanese models have that option already. Whether non heated side mirror Prius are prewired, I don't know. What I do know is I've run speaker wires to that location for tweeters before and it was not a difficult thing to do because you can just add the new wire to what is already there.
  12. JayG
    JayG Junior Member
    Talkeetna, AK
    2015 Prius c
    I know this is an older thread but I live 1000 miles further than most Canadians and my C2 doesn't have heated mirrors and I really need to install them. Last winter wasn't so bad but this winter has been rough. We haven't been above freezing for 6 weeks and I park outside. We won't be above freezing until late march probably. When you scrape the mirror it does virtually nothing at -20F but mess up the alignment of it . Honestly carrying deicer in a spray bottle is only half effective and It's dangerous to drive with them iced over from freezing fog.
    Has anybody successfully installed them on a non originally equipped car yet?
  13. When I checked last year, ironically, no one in Maine has and sells package fours
    but those heated side mirrors would have been so handy to get rid of all of the fog and sometimes ice... (n)
    #13 Deleted member 111882, Dec 26, 2016
    Got2bHam likes this.
  14. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    I've only had two vehicles with heated mirrors but ironically enough they take a long time to defrost. I'd rather have heated seats available on lower trims and maybe alloy wheels?
  15. JayG
    JayG Junior Member
    Talkeetna, AK
    2015 Prius c
    Heated seats and alloy wheels don't effect safety though. A cold butt for a few minutes and alloy wheels is further down the list than not being able to use your mirrors here in Alaska.
  16. Prius Sí
    Prius Sí Junior Member
    SoCal
    2015 Prius c
    Bumping this old thread as I'm hoping to tackle this upgrade in my '15 c2. Was there ever a definitive answer on whether the wiring is already in place so that the only thing needed is the mirrors with the heating element affixed?
  17. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    I didn't study that when I had my doors apart last month, but from a photo I took it looks like there are only 5 wires on the captive harness from the mirror assembly. I can't tell how many there are on the door-side of that connector block, but there is clearly space for more than 5 wires.
    So I think I'm seeing:
    position x
    position y
    position ground
    turn indicator hot
    turn indicator ground
    But that's just a guess, since I haven't bothered to rent the wiring diagram either. @ChapmanF has the right idea in post #8 above.
    The cars I've had with heated mirrors taught me that the feature is great for preventing build-up while driving in terrible conditions. Not very useful for removing whatever grew there overnight. I work harder to avoid terrible conditions now.
  18. Prius Sí
    SoCal
    2015 Prius c
    Thx for the intel, @Leadfoot J. McCoalroller. Checking out the image below from an OE heated side mirror assembly up for auction on eBay here, it looks like there are six (6) positions utilized on connector. Perhaps the the sixth is for the heating?
  19. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    Makes sense, would only need one hot and could use the same ground as the position motors.
  20. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    Has anyone seen the vehicle harness side and if that 6th wire is present on the lower trims? If so, then it might be as simple as plugging in a heated mirror or adding the element and wire. I read online either a Rav4 or 4Runner user said the wires were there they simply installed the new mirrors and it worked. A service manual would confirm the wire. There are also other add-on kits as seen below. I might pick up a Prius C so this caught my interest.
    Muth Mirror Systems - H-Mod (Heater Conversion kit)
    OEM Heated Mirrors DIY mod | Tacoma World
