Lack of spare tire: total cost to me $250 instead of $25
Discussion in 'Prime Main Forum (2017-2022)' started by antiglare, Aug 10, 2018.
  1. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    I've read my share of threads on the manufacturer's greed to not include a spare tire. Finally, lightning has struck and I got a slow leak in one of the tires on my Prime.
    Ordinarily, I would swap out the tire with a temporary spare, go to a gas station or tire shop to have the leak plugged, and be back on the road in a couple hours, all for about $25. Now, thanks to Toyota passing the cost directly to the Consumer, I had to use the included tire sealant and pump to seal the tire. Since sealing the tire effectively destroys the tire, I had to order a new replacement Toyo Nanoenergy tire (my car has only 3000 miles, so I didn't want to replace all four tires), which will come next Monday. I will need to take time off work to have the tire mounted onto the rim and balanced.
    Total cost: Toyo tire = $102 (Tirerack), new sealant kit = $117 (Toyota dealer), mounting and balancing = $30.
    I just can't help but shake my head in disgust.
    Mendel Leisk and frodoz737 like this.
  2. Elektroingenieur
    2,515
    3,284
    Three Touring
    I’d respectfully disagree. As I wrote in a previous thread, the sealant can make a mess, and Toyota says you should replace the TPMS transmitter (not included in your estimate) after using it, but if the damage to the tire is otherwise repairable, using the sealant shouldn’t prevent a repair.
    jerrymildred likes this.
  3. schja01
    schja01 Senior Member
    1,834
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    How much to replace the sealant canister?
    Edit: Sorry I see it was $117.
  4. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    In addition to making a mess, the sealant completely throws off the balance of the wheel, so that the car wobbles and vibrates until every last bit is scraped off. Due to the mess and the fact that the puncture is now gooed-up with the sealant, it's also more difficult to identify the location of the hole. At the end of the day, while it's theoretically possible to recoup the tire, it'd definitely not a sure thing.
  5. Washingtonian
    Washingtonian Senior Member
    726
    621
    I am trying to understand your logic. You have a slow leak on the Prius. You also have an Audi. Why didn't you just take off the leaking tire and wheel, put in your other car and take it to a tire store to be repaired? I had a similar problem, took the tire to Costco and they fixed it in about 30 minutes at a minimum cost.
  6. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    Discovered the leak at work, after noticing that the tire is practically flat. One way or another, I needed to get home, about 20 miles away. Most of the drive is on the freeway, so I didn’t want to just pump up the tire with the leak and take my chances on getting home safely without somehow stopping the leak.
    Of course, if I had discovered the leak at home, I could have taken off my flat tire and driven to have it repaired with my other car.
    MMBH likes this.
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Corporate greed is the reason Toyota didn't give you a spare?
    Well if anything, that's a new reason I've not yet heard. :)
    padroo likes this.
  8. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Toyo is the worst.
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Will the Toyota sealant eventually spread around inside the tire and balance itself?
    I put Ride-On sealant in the Toyos. This is described as a self-balancing product, and that some driving time was needed to let the goop spread. At first the car felt like it was running on bricks, but after several miles the ride smoothed totally out as the sealant got distributed inside the tires.
    I got rid of the Toyos. The Ride-On was a big help, but when the Mrs. picked up a screw in the tire, by the time she got home the hole was too big to patch. I was unsure of the safety of the plug (probably OK, but I didn't have confidence). The sealant kept most of the air in the tire, didn't allow much to leak around the screw, and got her home.
    The Toyos are very light tires. Very light casing which probably means a thin casing. I expect the OE Bridgestones are about the same...it's all for fuel economy. I bought a set of Bridgestone Drive Guard run-flat tires. Very heavy, and very reassuring. These 3rd generation run-flat tires ride well. Said to be good for 50 miles at 50 mph deflated (by then the tire's probably junk). The weight causes some economy loss, and I'll take the trade off.
    While the car maker saves money omitting the spare, the weight gain in the pursuit of fuel efficient gain is one main reason for no spare. Lack of a place to put the spare in the Prime is another big reason.
    dubit and antiglare like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Three things.
    1. Don't replace the sealant. Buy a plug kit and a regular 12v compressor. Cheaper and better. Then you not only don't have to take the tire to a shop next time, you probably wont even need to take the wheel off. Just plug and pump in place.
    2. Many motorcyclists put sealant in their tires as a matter of preventative maintenance. Not only does it NOT unbalance the tires, it improves the balance.
    3. None of these do any good if you have a blowout
  11. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    At least it's only happening 1/10 as often, right?
    I like the plug kit & compressor plan. I have a very inexpensive harbor freight compressor packed away in one of our cars. It's slow but easy to use and easy to carry.
    breakfast and jerrymildred like this.
  12. jerrymildred
    11,517
    14,152
    Tampa, FL
    Saved my bacon on the motorcycle once. Came back to the bike (20 miles from home) to find the back tire flat on the bottom side. (Why is it always on the bottom?!! LOL!) There was a big aluminum triangle about 1" per side sticking out of it. I put several plugs in it, pumped it up with the 12V compressor to what I thought was a good compromise between flex and pressure, and limped home as slowly as I dared in the traffic we have here. Whew!
  13. bisco
    51,966
    while i agree that some manufacturers are happy not to provide a spare, on plug ins, it is obvious that there is no place to put one.
    i carry one above decks for all the reasons you mentioned.
    #13 bisco, Aug 11, 2018
  14. frodoz737
    frodoz737 Top Wrench
    4,701
    2,499
    33
    Blow out, slow leak, sidewall or tread...10 minutes and I'm on my way with a spare. To each their own. ;)
  15. bisco
    51,966
    10 minutes? i'm a good half hour, and that's with a decent place to pull over and change it.:whistle:
  16. frodoz737
    4,701
    2,499
    33
    I've had a little practice. You should see me on a revenue gate turn.
    #16 frodoz737, Aug 12, 2018
  17. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    My Prime comes with a button on the ceiling and 3 years of free roadside service, including flat tires,lock outs, etc. Slow leak I might use my portable electric inflation pump I carry, but I don't plan on it. I have a spare I bought for my PiP I can use if I am in real need, but I will avail myself to their FREE service first! (Any Prime is less than 2 years old and comes with this free service.)
    I already have their service number programmed in my phone as well as knowing the location of that Toyota Safety Sense button which will also give them your exact location.
  18. TinyTim
    TinyTim Active Member
    383
    235
    Seattle
    Your Prius comes with Toyota Care. Why didn't you have your Prius towed to the tire shop free of charge? Then deal with the tire with or without the tire sealant?
  19. padroo
    padroo Senior Member
    2,763
    2,252
    Will Toyota Care take the car where you want or just to a Toyota dealer?
    By the way who has used Toyota Care.
  20. TinyTim
    383
    235
    Seattle
    I assume that Toyota Care will take you to a tire shop but even if it takes your Prius to the nearest Toyota dealer. That is better than ruining a $70 tire if that is a concern.
