Ladder rack on a Prius? Is it out there/possible?
Discussion in 'Gen 2 Prius Main Forum' started by alexknutson, Jul 3, 2008.
  1. alexknutson
    alexknutson New Member
    Louisville, KY
    hello! I'm a contractor for a local cable/internet company. For us contractors, the heavy burden (especially now) of filling our tanks is on us. When you're driving 100+ miles a day, the gas expense is literally in the thousands. My heart sinks every time I fill my tank. So I had the thought of buying a prius and sticking a ladder on top. At first it was a joke with some fellow contractors, but it would seem the demand for such a rack should be higher than ever. So I've tried to search on the internet for such a contraption but found nothing that would support an actual ladder (in my case, a 28' fiberglass). Obviously the car itself would not be long enough, and an extension in the back would be required to hold bottom of the ladder...however, is any such package available? I was hoping a post on the most popular prius forum on the internet would help on the matter. :rolleyes:
    I appreciate any information you all may be able to find. Thank you VERY much in advance!!!
    Respectfully,
    Alex
  2. McDonald
    McDonald New Member
    264
    Boston, MA
    If you put a Thule or Yakima or some other standard rack on the Prius (either the temporary ones that lock into the door frames, or you can bolt tracks on to the roof), I am sure you could secure a ladder to it. And the Prius does have hooks at front and rear for you to secure the ends of the ladder to. I imagine it would be not much different from having a kayak on top, which many people on here do (you can search the forums for it).
    Hope that helps a little?
  3. darelldd
    6,059
    389
    Northern CA
    How long is your 28' ladder when collapsed? Or are you talking about something that truly is 28'? Either way, a Yakima or thule would carry it just fine. Add gunwale clips, and you just need to tie it down - won't go anywhere. I do this all the time, though not with anything 28' long. Longest I've done is 16'. And I do carry a 16' kakak on me Prius as well.
  4. alexknutson
    Louisville, KY
    Well, the problem I have is that the ladder needs to be easily accessible multiple times a day. For example, if I'm doing 30 jobs a day, at least 20 are ladder jobs. So it will be coming on and off my prius alot. I need to be able to throw it back up there, strap a bungie cord or two, and be on my way because time is an issue. In your experience with the way you guys have it rigged, is this possible?
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    this almost sounds like it may be a safety issue.
    I would love a rack.. but all the material i carry seems to fit inside my car. 10 to 12ft if i leave the hatch open and tag with a red flag.
    How long is the prius? I'm only assuming roughly 13 or 14 feet. if an suv or other tall car were to approach you... i see a ladder going through their windshield.
    Not to mention pedestrian safety...
    would a collapsed 20 work? assuming it would depend on commercial vs resident installs...
  6. darelldd
    6,059
    389
    Northern CA
    Possible? Absolutely. Easy too. Easier than getting it on/off a truck, certainly. Put the Gunwale supports exactly where you need them once, then toss the ladder up, and strap it down to the rack.
    These are the brackets I'm talking about: Yakima Gunwale Brackets from REI.com
    Still looking for the answer about length.
    If I had 30 calls in a day, I'd probably kill myself.
    Akmzero likes this.
  7. Tim in Hollywood
    Tim in Hollywood Junior Member
    Hi Alex,
    Before you go too far with the thought of a rack for your existing ladder, have you thought of using a collapsible or telescoping ladder?
    These would fit nicely inside your Prius.
    Gorilla Ladders has a 21' ladder that stores at 5'7" long.
    I did Google searches for all of the following... (found some ladders that I had never seen before)
    collapsible ladder
    telescoping ladder
    folding ladder
    Ultimately, it completely depends on how long you really need your ladder to be.
    Later,
    Tim
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    You will beat the living sh*t out of a Prius doing Cable installs which will ruin its resale resulting in a negative $$$ impact on what you are trying to accomplish.. Its a urban commuter CAR,,repeat that CAR. Is there any other CAR that you can think of that might better suit you? Oh and its a really small and light car.
    Just get a used 4 cyl Nissan truck for christ sakes.
    Oh and if a cable guy pulls up to my house with a 15 foot ladder strapped to his Prius roof I'd laugh my you know what off.
  9. alexknutson
    Louisville, KY
    Thank you very much for the responses! It's helping alot!
    Tim_In_Hollywood, Unfortunately I'm not able to use any type other than a fiberglass ladder. Job requirement :(
    It's about 14 feet collapsed. I see those racks Dareldd and it looks like its exactly what I need. However, do any of you know what I need in the back to support the end? Something that can perhaps come out and up supporting it? This would be ideal so that I could lay the ladder first on this support beam, then slide it into place.
    V8Cobrakid, with proper flags posted on the end, I don't think any authorities would reject the idea. Although before I make my purchase, I'll for sure double check on that.
    Edthefox
    , you would have to know me and my personality to know this is a feasible idea for me as far as the investment goes. And I own a 4cyl Toyota pickup but even it is only getting 17-18 mpg. If I can cut that cost in half, I'd save over $500 a month in gas expenses. So you may laugh...but my checking account would love me. And frankly, Ed, I care more about my checking account then the opinions of my customers :) thank you though for your comment.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Personally I'd use a 4 cylinder ute. Not a Datsun though, never a Datsun.
    I'm not saying a Prius wont work, it could be the best thing. Get a second hand one rather than new to reduce the impact of knocking the car around for work and it reduces your initial outlay. Have a rear bar made which bolts on where a towbar would bolt to support the back end of the ladder. You may find a fitting for the receiver in a towbar.
    Can you have the vehicle you currently use converted to LP (propane) gas?
  11. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    I tend to agree with edthefox5 and believe that if you are loading ladders on and off your Prius (plus unloading God-knows-what-all-else from the interior) 30 times per day you are likely to beat it to death in fairly short order. I'm not saying that Prii are flimsy, but they aren't designed for heavy hauling and banging about either.
    This is one of those odd unintended consequence things, the effect of a sudden and dramatic increase in the price of fuel. People will inevitably begin taking steps to save fuel and in doing so cause themselves other sorts of harm, physical and economic. I think you'd be better off to buy a basic Tacoma, a 2wd with the 4cyl engine version can be had for around $15,000. It is very rugged, will last for years or even decades doing the sort of work you describe, racks are readily available and quite convenient and heavy-duty, and the mileage, while nowhere near Prius standards, isn't too bad and the $10,000+ you'll save in the initial purchase price will not only buy you a lot of gas, even at $4 or $5 per gallon, but the truck will bear up under that sort of use, something that I suspect the Prius will not.
  12. Tim in Hollywood
    Hi Alex,
    How about the foldable fiberglass ladder, then? They have those, too! ;)
    Ultimately, how long do you need it to be? A 17' fiberglass ladded folds to 4'6".
    Later,
    Tim
  13. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Yeah--the Prius is designed to be a passenger car, not a commercial van. If you're a cab driver, you're in business. But if you need a commercial van, you're out of luck.
    Try the Ford Escape hybrid. The 4x2 model. You'll get in the mid 30s on gas. About $30K.
    With gas prices rising out of control, the truck industry has been caught unprepared. Expect hybrid vans and trucks for commercial use to hit the market sooner than you think.
  14. Prius_Gnome
    Prius_Gnome Member
    81
    28
    Long Island, NY
    No one seems to have mentioned the obvious so here goes:
    The OP mentions that he wants to try to save money on gasoline by switching to a Prius (which an average person will probably get 40-50 mpg). But because he will need to strap a ladder to his roof, all the calculations will be whacked. The Prius aerodynamics are thrown off. I've read some posts stating that when someone adds a cargo rack, the mpg drops to 20s (ie. http://priuschat.com/forums/prius-main-forum/47920-beyond-dismal-mpg-cargo-rack.html). If I were the OP, I would also want to survey some people who carry kayaks and cargo on top to see what MPG they normally get. The gas savings might not be as high as you hope they will be.:(
    Also, the OP seems new to the Prius forums so he should also be aware that the wait lists are LONG for a Prius and that there is almost no way he's going to buy it for less than MSRP. He might even have to pay a premium over MSRP.
    I hate to be the bad guy here, but I figured you should be as informed as possible.
  15. V8Cobrakid
    3,790
    152
    with the hatch open.. windows down and roughly 1000lbs of material in the car.. i never get lower than 35.. which isn't bad.. because i currently get 40 with my tires...
    How about a trailer... you could carry all your extra materials since they are localized in the trailer (which may be easier than unloading the car... based off stacking design of a trailer "toolbox") and the excess length from the latter would be "covered".. since it would stick over your trailer and not someone else car.
    do you absolutely need that L bend at the end to hold the rear of the ladder?
  16. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
  17. darelldd
    6,059
    389
    Northern CA
    Small and light? It is the biggest and heaviest gas car I've ever had!
    I'd tip him. And then ask if he's considered going full EV.
    Oh, that's NOTHING! You don't need any extra support. If you've seen my pictures, you've seen a couple of kayaks longer than 14' mounted on a Prius. I've personally carried longer ladders that that. Just load them from the side. Child's play.
    Nothing at all. If you WANT something for the loading you are talking about, you can certainly mount a trailer hitch, and build or buy a T-shaped rack extender. I've done that before to hold a boat on my Toyota Pickup when I didn't have the camper shell on it.
    14' won't stick out either end enough to need a flag... though you may still want one for piece of mind, or because you really like flags. :)
    Remind me why we care what it was designed for? It wasn't designed to carry cargo or pull a trailer, but that's about all I use it for. And except for the part where it burns gas, I couldn't be happier with the situation.
    By a few mpg, yes.
    I won't bother following the link because I carry cargo boxes, ladders and kayaks on my car regularly. And I have NEVER gotten below 35 mpg even when flogging the damn thing. Normally I can still pull off 40mpg fully loaded with trailer and all.
    Done.
  18. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    A 14' ladder should be a piece of cake. And you'll have plenty of cargo space to store all the stuff you need to do your job. Of course you shouldn't expect to achieve 50mpg with all that weight in tow, either.
    But I have a feeling you're looking at this investment from more than just a pure economic standpoint. There's definitely a psychological comfort that comes from one's reduced pain at the pump, although in reality other commodity prices have risen even more than fuel (e.g. milk, bread, etc.)
  19. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    if the ladder is 14' collapsed.. you should be able to do this very easily and frankly easier than lifting it up to the height of a truck rack.. As for tools.. you might have a problem getting in and out of the hatch with the ladder on the rack.. could you get to the tools you need from the rear doors with the seats down?.. and yes.. a $500/mo savings in gas is WORTH ONE HELL OF A LOT!
    fyi.. the prius is 14.58 feet long.... no worries on the ladder length, hell I fit 10' long boards in the car all the time with the hatch closed!
  20. jump301
    jump301 New Member
    Malvern Pa
    We just installed a basic Thule roof rack system along with a hitch attachement and then a Thule "Goal Post" Pick up truck water sport carrier. We have a 28' ALuminum ladder on top and it works great. You do not even know it is there!
