LAPD to Test Gun That Immobilizes Cars via Radio Waves
Discussion in 'Fred's House of Pancakes' started by Arroyo, Jul 15, 2004.
  1. Arroyo
    Arroyo Member
    217
    45
    Los Angeles area
  2. pkjohna
    pkjohna Member
    228
    Manassas, VA
    Aren't the cars already stationary in LA? How can you have a high speed chase in heavy traffic? :roll:
  3. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    A high-speed chase in heavy traffic is also known as a Demolition Derby... :wink:
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I don't imagine they need to worry about accidentally hitting an airplane at 55' :) If it ONLY stops fuel injection, Prius owner's can still sneak away on electric. I'm more worried that the criminal types will be immobilizing the police cruisers. Imagine what would happen in Iraq if someone could force the Hummers and other military vehicles to a stop without even having to plant a roadside bomb. Sitting ducks all.
  5. KMO
    KMO Senior Member
    1,523
    401
    Finland
    2023 Prius Prime
    Heh, the joy of being the leading weapons developer :) Whatever you invent can be being used against you in a few decades. Can't wait until Bush's mini-nukes start proliferating. :roll:
    At least this one is relatively harmless.
  6. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    The concept is similar to that of the ElectroMagnetic Pulse (EMP) designed to overload the processor. I heard an article on NPR in which they talked with Dr. Giri about the technology. He admitted that they currently face the same problem that EMPs have: they emit radially and are difficult to aim.
    I didn't hear this issue addressed, but I wonder what they are doing about the delivery vehicle. Wouldn't a radio pulse designed to overload a car's circuitry also overload the circuitry of the car emitting the pulse? I remember reading about that with EMPs, they would often disrupt themselves. Perhaps they should issue '68 Novas as patrol cars.
  7. daniel
    14,487
    1,518
    Spokane, WA
    I'm skeptical of this whole thing. Sounds like someone's playing a joke on somebody.
  8. TonyPSchaefer
    14,816
    2,497
    66
    But Daniel, I read it on the internet. How much more credibility do you want?
  9. daniel
    14,487
    1,518
    Spokane, WA
    Well, okay... if you read it on the internet, that's different...
  10. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    I'm not so much interested in a gun that stops the car, as blowing out the overloud, over-amped stereo system at 2 AM in the morning.
    Old Mr. Grumpus
  11. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    anti-subwoofer zapper
  12. kenmce
    kenmce High Voltage Member
    1,528
    504
    NY
    The basic idea for an electronic car killer seems to trace back to the movie 2fast2furious. They had some hollywood special effects device that could stop a car electronically, probably with lots of sparks. All special effects go better with lots of sparks.
    One avenue you could pursue would be contact devices - a little missle that dumps a big electric pulse into the frame of a car upon contact. There is a slight problem that you would have to steer and aim at the same time. The US air force spends roughly one million dollars (us) per person to train people how to do this properly. Don't know how much your local PD is planing to spend on training. If you miss you have now unleashed a nasty little missle on the public. You would also have the problem of trying not to run over your own spent missle at high speeds after it did its job.
    Non contact devices would send a radio frequency/magnetic/electrical pulse at the target vehicle. Any wire or circuit trace can act as an antenna. If you can induce enough current in them you will eventually overload and destroy things.
    With a car like the Pri where a computer controls everything but the fuzzy dice, *Pauses* OK, including the fuzzy dice, it would likely destroy a critical funtion. Some problems with this:
    Right now we don't have anything that works. The metal body of a car will tend to shield its innards from passing RF energy. This is why you can drive past airport radars, high tension lines, 10,000 watt radio stations, etc, and not care.
    Electromagnetic energy tends to spread out sideways as it travels. That Cadillac dealership that you didn't really notice in back of your target could take as much damage as the intended target, maybe more.
    If you do kill a car in mid run you might well kill the driver and passerbyes too, say when their steer-by-wire failed catastrophically.
    Also, a large flat metal surface (billboard, passing semi) could bounce it back at you, leaving you feeling really stupid if you killed your own car by mistake
  13. bruceha_2000
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I see a new episode of the Keystone Cops coming!
