Laurel caynon causes my brake to smoke.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by terramir, Mar 3, 2018.
  1. terramir
    terramir Member
    318
    50
    Los Angeles
    it's kinda weird I expected the Prius to use the generator in the trans axle to brake if you apply light pressure just trying to keep within a reasonable speed on the down hill stretches of laurel canyon. for those outside of LA it's a long winded sharp curves up and down between Van Nuys (now Valley Glen) and West Hollywood (by the Whiskey, Roxy, Rainbow Room i.e. the sunset strip where the House of Blues used to be). Well by the time I get to Hollywood the driver side brake is burning and gets "stuck" I have to kick the rim multiple times to get it to stop dragging.
    two things since I got to replace my front brakes soon anyways. Since it would be convenient to drive that stretch should I go with rotors that have holes for better thermal management. Also #2 what is the cause of it starting to drag and then smoke like that? is there something else that might need replacing. Anybody got any ideas for a bolt on "as in it will fit without modifying crap" upgrade for the second gen so this never happens again? need new rotors and brake shoes anyways.
    terramir
    51,155
    have you tried b mode?
    WilDavis, Kevin_Denver and valde3 like this.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I've been to LA and driven there (not in the Prius) but it's like what 1000ft elevation? Didn't look very big.
    I do more than that daily in the Prius up and down. Brakes never smoke. I've been down Pikes Peak (14K to 7K feet, 7K feet drop), brakes never smoked. If you ride them they will get hot at the mandatory brake check points. But put the Prius in B mode and allow the engine to brake you and even Pikes Peak is no problem.
    Sounds like you may have another issue, like sticky brakes, that are just more prevalent during longer descents.
    Montgomery likes this.
  4. fuzzy1
    10,335
    When I descended Pikes Peak (only from Devil's Garden, as the summit section was snowed in), the traffic ahead was going too slow for me to get anywhere near enough B-mode engine braking. The slow-going leaders were downshifted to reasonable gears for their vehicles, but it was slower than I needed to make good use of B. The distance between switchbacks was too short to safely pass them, so I was stuck riding the friction brakes too.
  5. terramir
    terramir Member
    318
    50
    Los Angeles
    B mode only does so much at a max speed of 25 to 35 and yeah 1000 something ft up and down and up and down ends up being like about 1600 ft I think with needle turns and nutty drivers.
    How do you fix sticky brakes??
    terramir
  6. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius? When was the last brake inspection? Last brake pin lubrication?
  7. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Please check the caliper sliding (brake pins) bolts. If they are stuck and cannot move, this can create major braking issues.
  8. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The pivot pins need to be cleaned and lubricated, the front rotors and pads replaced, the rear drums inspected, and above 12mph the brakes shouldn't be doing anything, so, is the traction battery getting the charge above 12mph?
    I would think the Toyota techstream would be a good place to start, to find any problem, ie: the brakes shouldn't be taking the load, but they do need work.
    WilDavis and Mendel Leisk like this.
  9. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Lack of competent, routine maintenance.
    That's scary you are even asking that question.
    Routine maintenance, from a competent shop or a competent DIYer, would prevent this.
    #9 exstudent, Mar 4, 2018
  10. exstudent
    2,214
    905
    Torrance, CA
    There are raised contact points on the drum backing plate that require lubrication, for the drum shoe to move freely.
    Normal, "Gentle" braking, w/ gentle slowing, yeah, hydraulic brakes won't kick in until speed falls below 7MPH, IIRC.
    Harder and Panic braking, hydraulic brakes complement regenerative braking immediately.
  11. ChapmanF
    17,347
    Questions about the interplay of friction and regen braking at different speeds and driving conditions are very common on PriusChat, often making the answers seem simpler than they really are. There was another post last year that goes into it in more depth; it includes explanation of the Toyota graphs below.
    As for why the brakes might be dragging, it's true that a brake caliper is mechanically pretty simple, it has to glom on when you brake and let go when you don't, and it just has to be inspected carefully for why it isn't doing that. There's no rocket science, but there are subtleties.
    We talk a lot about the two little slide pins, often forgetting there's another large sliding component there—the piston—that had also better be sliding easily, or you'll be making plenty of heat. And there are two different things to check about the piston: first, that it simply moves easily inward and outward, and second, that it pulls back in by about 0.3 mm on its own when the pressure pushing it out is released. That pulling back is done by the internal rubber seal, and can stop happening if the seal gets aged/glassy. (In a badly rebuilt caliper, it may not pull back right from the get-go; test before installing!)
    Starting with Gen 2, the front caliper pistons are also made of a phenolic resin instead of metal, which Toyota chooses because of several advantages, but there is a disadvantage in very rare cases where the material can swell, and then the piston binds in the caliper and needs to be replaced.
    When I say "very rare", I mean I have only seen one case on PriusChat ever where swelling of the piston turned out to be the issue. There's one other thread where somebody heard about that possibility, and got sort of fixated on it, saying all kinds of disparaging "plastic is for kids' toys, I'll buy real pistons aftermarket" kind of stuff, only to finally figure out there was a ridge in his caliper bore and it wasn't piston swelling after all. As I said, the swelling seems to be really rare, and require pretty special driving and environmental conditions.
    That's a good thread to look at anyway, though, because it does tell a pretty good story of just carefully examining things and going through the possibilities until the problem is found.
    -Chap
    2k1Toaster likes this.
  12. terramir
    terramir Member
    318
    50
    Los Angeles
    Routine maintenance on prius is replacing the brakes about every 7 years lol. Jokes aside. I have never had a sticking problem like this because all my other cars and trucks didn't need brake replacement only every 100k+ miles (was more like every 2-3 years aka 24 to 36k miles) So when you replaced the brakes and lubricated everything etc. you never got to these issues every third or 4th brake job you replaced everything (rotors piston's etc.) on a prius you replace the pads every 100k the discs maybe every 200k and the pistons should last the life of the car (with regen braking and everything.)
    Scary no never had that problem on a fox-body mustangs cause the replacement cycle was to quick for sticking to ever show up, neither did this ever happen on my trucks also a 24k replacement cycle. will inspect the pins and piston as suggested when I get new pads and rotors but for now I'm staying away from laurel canyon.
    terramir
    PS: would drilled rotors improve this situation (the overheating part)?
  13. Mendel Leisk
    40,584
    Toyota recommends a full brake inspection every 30K miles or 36 months, whichever comes first. Look in your Schedule Maintenance Guide to verify.
    WilDavis likes this.
  14. exstudent
    2,214
    905
    Torrance, CA
    No. The underlying cause needs to be resolved.
    The cross drilled rotors are probably more expensive than the factory vented rotor. Also cross drilled and slotted rotors will wear out the pads faster, b/c the cross drilled holes or slots, will act like a grater to the cheese (brake pad).
    Cars leave the factory with brake components that are matched for the cars weight, power, and original vehicle driving characteristics (econo commuter, semi-performance, performance, etc), for the least amount of cost. Manufactures could equip every car w/ vented and cross drilled rotors, and oversized brake calipers and oversized brake pads, but this will increase the purchase price of the car and brake maintenance. Even a lowly Toyota Yaris could have this extreme brake set-up, but it would be overkill.
    If the factory car were modified for performance: intense engine modification or replacement, turbo/super charger, suspension, exhaust, transmission, bigger/wider tires, etc, increased stopping power via larger upgraded rotors (slotted and/or cross drilled), upgraded calipers, larger pads, and usu an upgraded brake master cylinder. Recall the Mazda Miata enthusiasts who do an extreme engine swap of the lowly 4cyl Mazda engine with a Ford Mustang 5.0L engine, Chevy Corvette 5.7L engine, or a turbocharged RX-7 engine, in addition to a suspension, transmission, and intake and exhaust overhaul. The original factory brakes would be insufficient for such a performance modified car. These extreme enthusiasts know it, and correctly upgrade the brake components too.
    Now if you modify the Prius like those Miata enthusiasts, you would want to upgrade the factory Prius brake system somehow. You don't drive a Prius to set any typical performance metric: 0-60MPH, 1/4 mile, track lap time, etc. You drive a Prius to set MPG records.
    Get the brakes fixed and all will be well. Use B mode on "steep" descents, to minimize the potential of overheating the brakes.
    #14 exstudent, Mar 14, 2018
    WilDavis and valde3 like this.
  15. terramir
    terramir Member
    318
    50
    Los Angeles
    I bought this car about 2.5 years ago without any maintenance guides as it was already almost 12yrs old. my car was sold in oct of '03 the 1st time. inspect every 30k was done less then 10k ago had like 8mm left on the pads the rears seemed a lot more urgent at the time and those I replaced about 10k miles ago. they did tell me the rotors had to go could not be ground that they were too close to min spec but the pads were still good.
    Gonna check the brakes this weekend. But here are some choices I have for replacement in my current budget.
    Front PowerSport Replacement Brake Rotors and Ceramic Pad 2004-2009 Toyota Prius | eBay
    but I could afford these
    Front Drilled Slotted Brake Rotors and Ceramic Pads 2004-2009 Toyota Prius | eBay
    it's $38 vs $57 so like about $19 more and well of course I got figure out if it's the pistons or the bolts duh or a general lack of lubrication on the brake parts they are quite old after all.
    they did an inspection 10k miles ago not a service I replaced the rear brakes about two weeks after that inspection.
    terramir
  16. terramir
    terramir Member
    318
    50
    Los Angeles
    Hmmm I Drive a prius to be able to afford driving, but the way I drive I can get 40+ on the freeway heck 50 if I take it easy, but with the condition of my battery and the way I drive I get more like 15 to 25 in the city. overall hmmm 30 to 37 depending on my freeway driving amount. if I had a decent battery I could bump that up quite a bit. to like 40-45 but 50+ not happening with my "sporty" city driving, I actually call it get out of the way of idiots the electric motor really helps with lower end torque. but yeah brakes could use a notch of upgrading. mind you I used to get 10 miles a gallon(city 20 fwy) with my mustangs but heck 30 to 37 with a 14yrs old car not too shabby.
  17. bisco
    51,155
    get out the way!:eek:
    WilDavis and Raytheeagle like this.
  18. terramir
    terramir Member
    318
    50
    Los Angeles
    Yeah in Los Angeles You really get the impression that half the drivers bought their licenses at McArthur Park (yes from that donna Summer song) or bribed the instructor to pass lol.
    But on a more serious note considering those are bargain basement pads and rotors should I go with the drilled and slotted one? Buying new pads in 2 three years if they really cheese grate (although if you look they got lip relief built in) but honestly laurel canyon is a bit** and I would really like to drive this quite often any additional cooling would probably help.
    terramir
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes, mid-40's to high-40's on a Gen-2 with a good battery is normal for "drive it like you stole it" mode. With the range you're getting, I'd be pocketing a little bit of money when you can to replace the inevitable. That MPG is within the battery-is-about-to-fail range.
  20. terramir
    terramir Member
    318
    50
    Los Angeles
    My biggest problem is imbalance will keep showing up, I'm having a hard time sourcing decent modules. if I could get 2300 bucks together I would buy a toyota refurnished one if I'm right and correct me if I'm wrong, they use all new modules on those just reuse all the hardware. 28 new modules I should be good for another 150k miles :- ). But right now I gotta finish my wire harness for charging discharging still working on designing and 3d printing the power port, that will be darwin proof.
    (set-up is this led power supply (350mA CC floating voltage)a 12V brick (for the fan and powering the SSR that switches the led supply on. childproof outlet for the discharge rig a panel meter and a switch and a box.
