Leak in AC system
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Carsten, Apr 28, 2024.
  1. Carsten
    Carsten Junior Member
    28
    Columbia, SC
    Hi all,
    I did a vacuum test on AC system and it would not hold a vacuum.
    Then, after watching a youtube vid, I pumped compressed air into the low side valve to see if I could feel/hear a leak. I did hear air, it was coming out of a hard line that runs up into the front fender. I assume this to be some sort of overflow/drain line, and that this should not be leaking.
    On this hard line there is a little block where the high side valve is on the side of that there is something plugged in. Could this be a solenoid to open and close this line? Maybe this is faulty?
    Thanks, Carsten
  2. ChapmanF
    15,614
    On a gen 3 that would be the pressure sensor. Probably same on gen 4.
    System should not have any solenoid-operated refrigerant drain lines....
    Carsten likes this.
