Leak into Trunk Floorboard
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by jyii07, Oct 18, 2020.
  1. jyii07
    jyii07 Junior Member
    39
    NYC
    It's been raining here at least a couple times a week recently and after each rainfall whenever I'd open up the trunk a bunch of water would pour out of the trunk latch area (circled in blue). Didnt think much of it and thought the water was all running towards the outside. However, I opened up the floorboard today and found a huge puddle of water which also destroyed all the foam that was there. Any ideas of how to troubleshoot? I don't see any blockage and no debris or leaves stuck in any areas.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Yuck!! I think I'd start by removing the plastic panels inside the lift gate. It might be coming in via either the garnish (the piece that has the release button) or the license plate area. Removing the interior panel will let you see the backside and any traces that might be visible.
    #2 jerrymildred, Oct 18, 2020
    52,404
    maybe a bad seal? i don't recall seeing this in gen4
  4. jyii07
    39
    NYC
    Thanks, ill give that a shot...
    yeah same.. tried searching around and people only mentioned this on the gen2. Supposed to rain again soon so ill check to see if any more water gets in there.
  5. bisco
    52,404
    if it continues, climb in the hatch and have someone hose it down
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,158
    Tampa, FL
    Good idea. But I think there's a better chance of seeing the leak if you take off the plastic inside panels so you can see the car's skin from the inside, so to speak. It just pops off on previous generations. I imagine that Gen 4 is similar. You might look for a Youtube video.
    Merkey likes this.
  7. jyii07
    39
    NYC
    Will give that a try also. On a side note, is there any con to removing the foam parts that hold the jack and tire repair kit? They were destroyed from the water anyway so I just threw them out and put a spare tire in the space. The floorboard is a bit uneven but I have an all weather liner on top that helps.
  8. jerrymildred
    11,517
    14,158
    Tampa, FL
    Not particularly, but you'll want something to support the cargo deck. Someone recently posted pictures of a frame he welded up to do just that, but I can't remember right now who it was. Also, I think that those foam parts reduce road noise.
  9. jyii07
    39
    NYC
    I have the all weather liner mat on top of the cargo liner. Just came back from a trip where I loaded a bunch of stuff on top of the uneven cargo deck and thankfully didn’t notice any issues. I definitely do think that I should put something back there to support it but can’t find anything easily accessible.
  10. jerrymildred
    11,517
    14,158
    Tampa, FL
    @jdenenberg mentioned in August that he had the foam insert for the spare available. If he still has it and you're interested, maybe you guys could arrange something. (See post #10 here. How to remove the Styrofoam compartments for tire repair kit (Prius Camping) | PriusChat)
  11. jdenenberg
    jdenenberg EE Professor
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
  12. jerrymildred
    11,517
    14,158
    Tampa, FL
    I just had noticed that @jyii07 is in NYC, so thought it might not be an insurmountable distance compared to what most of us would need to travel. ;)
    krmcg likes this.
  13. jyii07
    39
    NYC
    Ah, see that you're in Trumbell, CT? looks like thats around 1.5 hours from where I am... do you have any idea how much shipping would be? I'd obviously be happy to pay for shipping and however much you're willing to sell the parts for.
    @jerrymildred , appreciate the post and for pinging JeffD. Thanks very much.
  14. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    If the foam insert deal doesn't go through, I'd be interested in the parts--want to get a spare into my 2019, which only came with the goop and the compressor.
    jdenenberg likes this.
  15. jdenenberg
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    we could meet halfway (White Plains?) and avoid the shipping issue. I have the central foam insert and the tire tie down screw (not the bracket that needs to be in the spare tire depression).My significant other puts the price at about $50. I also have some of the rubber mats from Toyota, Front (both sides) and Hatch.
    JeffD
    #15 jdenenberg, Oct 29, 2020
  16. jdenenberg
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    As did my 2020 AWD-e, but my spare tire well contains the power electronics for the rear axle motor so the parts that I salvaged from my totaled 2016 Prius 3 will not work for me.
    Jeffd
    pjksr02 likes this.
  17. jdenenberg
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    @jyii07 Are you still interested? If not I'll offer the foam insert to @pjksr02
  18. jyii07
    39
    NYC
    @jdenenberg Sorry for the delay... I cant seem to PM you. Do you have an email I can contact you at?
    #18 jyii07, Nov 1, 2020
  19. jerrymildred
    11,517
    14,158
    Tampa, FL
    Right under his avatar is a link that says, "Start a Conversation." Click that to compose and send a PM that will go to the email address he has registered with Prius Chat.
  20. jyii07
    39
    NYC
    Thanks @jerrymildred.. tried that but was getting the below error. However, I see that I already started a convo with jdeneberg back in September on the same spare tire inserts :). I just responded in that convo again.
    "Page Not Found
    Oops, something went wrong.
    We could not find the page you were looking for. But, maybe we can help.
    Navigate through our top menu or contact our team, browse the forums or search for the keywords, to find what you were looking for. Or, start a new discussion by clicking on new thread, and open the conversation :)"
