Leak source for battery fan wiring loom corrosion?
Discussion in 'Gen 2 Prius Technical Discussion' started by TonyR, Oct 29, 2024.
  1. TonyR
    TonyR Junior Member
    I posted a while back about fault codes coming up on my otherwise very reliable 2004 Prius and folk pointed to water-leaks corroding the wiring related to the battery cooling fan. I’ve now had some time again to investigate and that is indeed the problem and it’s been repaired. So all good there.
    The question though as this seems to be a standard problem, is where is the water leak coming from. I know from experience that tracing the source of a water leak can be difficult as water runs along things and appears far from the leak site. So for those that have been there, any advice on where to look and how to fix it?
    Thanks
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    Use the search feature and look for "tailgate water leak" in the Gen2 forums. The most common problem is cracked seam sealer around the tailgate opening on the body.
    Look around the lift piston mount and up into the rain gutter on the roof under the black rubber strip.
    Quick fix is to clean and dry the affected areas. Reseal with a good caulk. (Automotive seam sealer like 3M # 08505 is more $$ but will last longer)
    Brian1954 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    12,998
    2,330
    Durham NC
    Quick is to open water pass they plugs in that area . Fix plug of fan zip tape the repair. Move plug over about two inches . It'll never get wet generally again and water passes thru chassis as designed . PDI was done incorrectly as far as I'm concerned . Rubber plugs need be put in strategic places
    51,962
    another weak spot is the rain gutter weld underneath the black molding
  5. TonyR
    TonyR Junior Member
    Thanks!
  6. TonyR
    TonyR Junior Member
    Sorry, again in English?
  7. mr_guy_mann
    4,048
    1,974
    NJ-USA
    Translating from "Tom-ish" to English.
    Repair and mitigate the symptoms but don't fix the leak.
    Not my preferred strategy.
  8. Mendel Leisk
    41,475
    Anyone else thinking of the lineup scene in The Usual Suspects? ;)
  9. Tombukt2
    12,998
    2,330
    Durham NC
    Water sposed too be allowed to pass thru chassis by design reason for the plugs in first place.remove them and pass thru occurs as it designed . Now you can strip off stuff to fix the bonding points that failed at ones leisure. Because the liquid won't ruin anything . It's not living in the space it's just passing through as designed generally won't hurt anything.thats all . This is done so you don't have to line dry the chassis suspending it like by the trailer ball or receiver like the laundry.like the doors in monsters once he he. Toyota has made boats before.
