Leak under car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ingyaningya, Mar 13, 2016.
  1. ingyaningya
    ingyaningya Junior Member
    70
    17
    Miami
    I just realized this leak under my 2007 Prius not too long ago. Attached is an image of the leak, and I circled where it is coming from. It is coming from the front of the car. Is this an issue? Any suggestions?
    49,732
    i think so. there are several places it could be coming from. you'll probably have to get under there, clean everything real well, than look for the culprit with a bright light.
    can you determine if it's oil or coolant?
  3. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I try to see if is oil or water...coolant is pink. Pretty common to have water pump leak which normally you see pink salts by the water pump. Check your radiator coolant, make sure its got the Toyota pink fluid and is full to the radiator cap. Check your oil level.
  4. xliderider
    xliderider Senior Member
    7,895
    3,129
    Honolulu, HI
    Place a sheet of white paper under the car to catch the fluid dripping from the car. Hopefully it will better show what color and consistency it is.
  5. JC91006
    16,496
    8,406
    Looks like it could be water from you AC unit
  6. ingyaningya
    70
    17
    Miami
    It seems clear, and it's very humid and hot where I live, so I believe it is in fact simply the A/C.
    On a separate note, does anyone know what all that white stuff is coating the bottom of my car? How can u clean that off without damaging anything?
  7. bisco
    49,732
    did it come from snow country? looks like salt. you can do an underbody wash at some car washes.
  8. Mendel Leisk
    38,896
    Look for AC water outlet hose, that'll confirm or eliminate that possibility.
