LEAKING AC CONDENSER PREVENTION
Discussion in 'Prius c Accessories and Modifications' started by lech auto air conditionin, Feb 25, 2023.
  1. lech auto air conditionin
    830
    601
    261
    san francisco
    Condenser coil coating made for heat exchangers
    1: if you live anywhere near coastal regions by the Ocean
    2: if you live anywhere during the winter that the roads are salted for ice prevention
    3: if you live anywhere, there is a lot of sand blowing as you’re traveling, 65 miles an hour down the freeway it’s a fine sandpaper, like abrasion constantly eating away at the surface of the metal tubes of the AC condenser
  2. ChapmanF
    15,435
    Available in spray cans or as stuff to spray with your own HVLP rig.
    The HVLP data sheet gives more detail on how to apply it. The spray-can one tells you to apply it with no runs or sags and to a dry film thickness of 10 to 36 μm, so at least after you're all done you'll know how to tell if you did it wrong.
  3. lech auto air conditionin
    830
    601
    261
    san francisco
    yes, I bought an entire case of spray cans and a entire case which is 4 gallons of the liquid for the HVLP gun. Because I spray it on my commercial Evaporators in Condenser’s..
    Especially on my personal or family as units.
    If you’re evaporator condenser leak on a split system, it will be a few thousand dollars to have it replaced.
    To extend the life five or 10 more years a $30 can of coil coat is well worth it.
    Especially for the people who live right next to the ocean coast we’re getting 4 to 5 years is a miracle if they’re condenser is still in one piece.
    And we all know how Prius condensers like to leak
