Leaking Windshield Washer tank
Discussion in 'Gen 5 Prius Main Forum' started by Swauger, Sep 7, 2023.
  1. Swauger
    Swauger Member
    37
    34
    PA
    Got our new car home 2 and a half weeks ago. Soon after we got it my wife told me the windshield washer fluid wouldn't come out and spray the windows. I told them maybe they forgot to fill it or tip it off. No big deal, she filled it herself and it worked fine. 5 or 6 days later I went out to check the car and the WW fluid level. Son of a B*tch it was gone. As in you couldn't see any in the clear/translucent tube. I figured she just put a little in and I topped it off and told her to make sure she filled it to the top. She swears she did. I checked the car last Friday night. It was missing again. Topped it off for the 3rd time and called the dealer to have them to take a look at it. Wednesday morning came and before I left for the dealership I figured I better look to see if it lost any more or I would look like an idiot for taking it in with no issues. Yup, it was gone again. Looked under the car on the garage floor and there is no liquid. The dealer spent 2 hours looking at it and said there is no leak that they could find and to "keep an eye on it." I told them that I have and it's been topped off 3 times in 2.5 weeks. He shrugged his shoulders and handed me the paperwork. I asked what's the next step. He said you leave the car with us for 5-7 days for us to find the leak. I told them that was fine as long as they had a loner/rental for me to use. My wife needs the car to get to work. They told me that wasn't an option. Asked for the Service Manager who "was out of the office that day." I left a message for him to call me and he magically called me in an hour. I'm sure he was there but the service rep didn't want to pass me off. He told me that if its leaking, to stop in and his techs will take a look. I told him it was just there for two hours and they couldn't find anything. He then asked me where on the floor is the liquid going. I told him it's not on the garage floor. Only a small amount leaks out daily. He told me that I would have to have them look at it again because they can't order a replacement part until they have proof it's leaking and know where. I told him the tech topped off the fluid to the very top. I took a picture. The next morning it's down half an inch. And no water on the floor primarily because the undercarriage is pretty much enclosed. It's not like old cars where you can look up underneath and see belts, hoses, pipes, etc.
    I called Toyota and they said they would look into it and get back to me. I'm not holding my breath Day 0 - 856 am - topped off at Dealership on Wed Sept 6th.jpg Day 1 - 523 am - Checked last night at 9 pm and it was topped off exactly to the top.jpg . Any recommendations on what I can do next or should ask for from the dealership?
    Images are of yesterday at the dealership at approximately 9 am and this morning at 530 am. Roughly 20 hours later.
  2. Mendel Leisk
    38,727
    My hunch would be that topmost bit is leaking out a joint between the neck and main bottle. Workaround (if that's it) would be to not fill up into that neck.
  3. Trollbait
    11,561
    If you can, drop the belly pan, I've had one hide an oil leak, as it caught all the fluid. They should have done so, but...
    I wouldn't expect that to empty the tank to the point of no spraying.
    Mendel Leisk and JohnPrius3005 like this.
  4. Mendel Leisk
    38,727
    Mighta been initially unfilled? Then after fill, it’s leaking just at neck joint?
    @Swauger is there a dipstick? Checked? <2023 Prius Owner's Manual (US pdf) makes no mention of dipstick.
    #4 Mendel Leisk, Sep 7, 2023
  5. bisco
    49,492
    leave it with them overnight so they can note the drop in level
  6. Trollbait
    11,561
    I have never come across a dipstick for the washer fluid tank. Would be nice, in that the tanks are now buried underneath other things. I think the Outback has a low level indicator light. Doesn't help when I'm peering down the tank filler neck, wondering if I should pull out the bottle though.
  7. aforkosh
    aforkosh Active Member
    413
    262
    Oakland, CA
    2023 Prius
    1) The 4th generation did have a dipstick in the filler tube.
    2) From the 2023 non-Prime owner's manual (page 421):
    "If any washer does not work or “Windshield Washer Fluid Low” is shown on the multi-information display, the washer tank may be empty."
  8. bisco
    49,492
    either our pip or former hycam had a dipstick. i've never used it, just top it up from time to time
  9. Mendel Leisk
    38,727
    Our ‘10 has one, long, yellow strip, with grip tab at the filler neck, perforations along the length and some text.
  10. Trollbait
    11,561
    If the 2016 Camry had one, it was hidden.
  11. Gokhan
    Gokhan Senior Member
    4,655
    1,866
    Paramount CA
    #11 Gokhan, Sep 8, 2023
    JohnPrius3005 likes this.
