Leaky left axle seal replacement at Dealer - $470
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by swoop, Aug 23, 2010.
  1. swoop
    swoop New Member
    Chicago, IL
    I
    The dealer told me that my 2006 Prius with 74,000 miles has a leaky left axle seal and it would cost ~ $470 to replace it. The cost of the unit is $15 and rest is labor (Chicago). Is this a reasonable quote? Can a local mechanic do the job or should I get this done by the Toyota techs?
    Any inputs are greatly appreciated!
    Thanks!
  2. Patrick Wong
    18,200
    6,479
    The price is high but seems normal for dealer service. A local mechanic can do the work.
    I recommend that you ask the mechanic to disconnect the 12V battery before starting work, to avoid causing problems to the skid control ECU and the brake system.
  3. swoop
    swoop New Member
    Chicago, IL
    I
    Thank you!
  4. whitecraine
    whitecraine New Member
    Hmm, perhaps the price is going down now. My dealer gave me a quote of $340 for the same problem on my 2006 prius - and with the 15% costco discount, should go down to $290.
  5. El Dobro
    El Dobro A Member
    6,985
    3,218
    Al Capone Toyota? :p
  6. Mike500
    Mike500 Senior Member
    2,593
    764
    NOT "Cap one." More like cap your knee with a "ball peen hammer.":(
