Least Expensive Way to Get a Back Up Key Fob and ? About Battery
Discussion in 'Gen 2 Prius Main Forum' started by Keri Weeg, Jul 14, 2014.
  1. Keri Weeg
    Keri Weeg Junior Member
    Fort Myers Beach, Florida
    I just bought a 2008 Prius and couldn't be happier! 131,000 miles but the CarFax was clean and the car is immaculate. I would like to know the cheapest way to get a backup key for it (my history of losing keys is something I'm not proud of). I would also like to know if it's normal for the battery not to show a complete charge. Mine has been ranging from 3/4 full to one-bar-from-the-top full, and I'm averaging between 40 and 48mpg, city, since I bought the car one week ago. Any other tips for this Prius newb would be appreciated :)
    Daves09prius likes this.
    51,157
    welcome to priuschat! sounds perfectly normal. you can get a fob on ebay and program it per the threads here on the subject, (search: chicken dance) it's hit or miss. or you can try a locksmith with the proper equipment. otherwise, the dealers gonna want 3-400 bucks. and don't lose the one you have, or else you'll need a new computer too. all the best!(y)
    Daves09prius and Keri Weeg like this.
  3. JC91006
    16,674
    8,519
    It's best to get the keys from a Toyota dealership, that way you know for sure they are Brand New. Only a Brand New key can be self programmed. The keys are about $105 each online.
    Autonation Gulf Toyota has a promotion this month that gets you additional 5% off by using promo code july2014
  4. usnavystgc
    3,159
    990
    Tucson, AZ
  5. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Welcome to PriusChat!!!
    Keri, please keep us posted I only have one key as well and have always wanted a backup. I completely understand about losing keys... I've had to dig through the sofa too many times. A back-up key has been on my Prius-to-do list for awhile. I keep meaning to take care of it, but I never do.
    Any information you can share on your adventure to get a new key would be helpful.
    Oh, one other thing to keep in mind for your search for a key: On the back side of the fob, if the Toyota symbol is black, this normally signifies that this is a non-SKS key. If the Toyota symbol is chrome, this normally signifies that this IS an SKS-key. (SKS is the security system.) I see in your Avatar description that you have a Prius model four, most likely you have the security system, so you'd need an SKS enabled key.
    bisco, JC91006 or usnavystgc any other advice for Keri?
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    No but, my advice for you is to read the thread I linked, buy yourself a key fob and, post your results in the sticky. :)
  7. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Aaron Vitolins and robert mencl like this.
  8. bisco
    51,157
  9. AllenZ
    640
    63
    Chicago
    He probably use the same name on ebay as well as here:
    ovnisf
  10. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    I'm also thinking of buying one of these keys for my Prius. Cheaper than getting a keyfob and easier to program. And plus I just need it as a spare. My question to you is, can this key be hooked onto a keychain? Probably not since you have to insert the key into the ignition now right?
  11. MortenAZ
    MortenAZ Junior Member
    26
    Phoenix AZ
    You just want a spare key? I did a quick Google search and followed the instructions to program an original Toyota key from another prius to work on mine. I took my insurance card with me to the dealer and he cut a new key from the vin for $4. It only took me about 5 minutes to program the key. The key does not work other than being inserted to start the car. No remote and definitely NO sensor. It is exactly what I want. I have it in a locked safe in the car.
  12. Barbara Basel
    Barbara Basel New Member
    Morristown, TN
    Don't mean to alarm you, but, from what I have heard and read, you can ruin your car if you are driving with some low battery cells, and that might be what is happening here. BUT, don't take it to a stealership, take it to another certified mechanic because dealers want to replace the whole battery pack and will charge thousands for it. Or, you can check it out yourself on youtube, or take it to someone who does this and they can replace the cells for a resonable price.. I wouldn't do it, but I know people who have replaced cells from youtube instructions. BUT follow the directions very carefully. Prius's can easily short out if you don't unplug the battery before you do anything on them. The cells run about 38 to 50 bucks, labor is not bad, and there are individuals that just replace cells in hybrids.
